I have Toshiba satallite with black screen and I did several solution to fix the problems but did not work though....
    Scholar:
  • 89 Answers
Connect an external monitor on your computer. If you saw windows coming up on external monitor,there's a need for you to send the computer to the nearest service center to get the graphics cards and LCD checked. If it will still give you black screen upon boot up, just re-install Windows.
Posted on Mar 14, 2011
  • Hanna Katrina Arboleda
    Hanna Katrina Arboleda Mar 14, 2011
    1. Disconnect all external devices (printers, USB hubs, USB drives, etc...)
    and then boot up.
    If this corrects the issue then add the devices back one at a time until you
    discover the piece of hardware causing the issue. Then get any updated
    drivers\software for the device.
    2. Use the"Last known good configuration" from the Windows Advanced Options
    menu.
    If this option resolves the issue then look for any updates or software
    installs that may have caused the problem.
    3. Boot to Safe Mode from the Windows Advanced Options menu.
    If you can get into safe mode then the issue could be driver or software
    related.
    From within Safe Mode run a System Restore.
    4. Perform a Clean Boot
My laptop toshiba satallite pro L300 usually experience blue error screen noted dump physical memory and cached problem... how can i get rid of it?
LOL one fellow said it was sledge hammer time for his . try getting into the BIOS and reset configuration to original
Feb 19, 2015 | Toshiba Satellite Pro L300 Notebook
Toshiba satallite c675d-s7109 fan only works
A problem with the screen
Try putting the OS again
Mar 06, 2014 | Toshiba Satellite Computers & Internet
Have a black line across the screen on my Toshiba 32AV502R LCD TV, no matter what input I'm using. It started as a bunch of visual "noise" and after turning it off and on several times,...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken
Good luck in solving the problem.
Jun 09, 2011 | Toshiba 32AV502R LCD TV
My toshiba satallite l305-s5909 wont display a screen. I turn it on and after the toshiba logo goes away the screen turns to black with a funny symbol and cursor blinking in the top left corner
Restart your laptop, as soon as it powers on (even before you see the logo), repeatedly tap on F8 to get to the advanced boot menu. Select the option for Last Known Good Configuration and see if it would boot up. If not, Repeat the procedure but this thime, choose safe mode. If you're able to boot to safe mode, you can just do a system restore to a date when it was working fine.
Apr 06, 2011 | Toshiba Computers & Internet
My toshiba satallite is not working
i think u should format your system sir.your os needs reinstallation
Mar 31, 2010 | Toshiba Satellite A105 Notebook
TOSHIBA L20 ****
You'll have to have it serviced. Most likely the hinges and or the lcd brackets are broken. It's not something the average home user should fix themselves.
May 11, 2009 | Computers & Internet
Black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Sep 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
