Question about Microwave Ovens
Does the maytag mmv1164ww1 micro/hood combo require outdoor venting?
  • 33 Answers
No .. it can also be recirculated . you will need charcoal filters if you do so. There is a specific charcoal filter for each microwave hood. Any appliance part dealer would carry it ( you will need to give them the micro hood model number ) or you can order them online through Whirlpool parts website ( whirlpool owns maytag)
Posted on Mar 14, 2011
I have a maytag micro/hood combo that stopped working the other day when it was used. We thought the timer was set for 18 min, however the microwave was actually cooking the entire 18 min. The unit worked...
Try a hard rest of the electronics to restore unit to factory defaults. If that does not do it your logic board has failed and if not too expensive you might want to replace it. Check it out at site Search Over 2 1 Million Appliance Parts
Sep 03, 2017 | Maytag Microwave Ovens
I need a users manual for my maytag microwave overhead ove #umv1152baq serial#51360947
I did not find an EXACT match to your model number, but I did find an owner's manuals for the Maytag UVM1152 series that may work for you.
If this is a Maytag Microwave/Over the Range Hood Combo, you can go to managmylife.com and download or print for FREE. Just enter the model number as "UVM1152" under the "Manuals" link and review the manual listed to see if it will work for your oven.
For your convenience, here's a direct:
http://www.managemylife.com/mmh/owner_manuals/14763/MAYTAG-Microwave-Hood-Combo-L0605243?brand_name_search=umv1152
There's also an installation manual available.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 11, 2010 | Microwave Ovens
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
