This unit is practically brand new, has no dust nor dings nor damage on the unit anywhere, not even a scratch, but I haven't been able to get the unit to power on. Power cord is connected. The switch on the unit sounds like the others when pressed and everything looks and smells good inside and out! There are no cracks on the circuit boards, no broken wiring no broken or missing or out of place connectors. The fuse is also intact and appears good, but I haven't used a meter yet to check for voltages anywhere. I'm hoping the problem might be something simple. I currently don't have the remote control for the unit.
  • Jesse Mar 27, 2011
    The outlet is live. Nothing has happened on the front panel when the power was switched to on. The only sign of life has been a blinking led on the back of the unit at the optical input connector.
  • 2,098 Answers
Hi jesseley,
Do it has a led light when you plug the unit to the outlet, make sure that the outlet is live, what happen when you pressed the power on switch in the front panel?
Jdvillanueva
Posted on Mar 14, 2011
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    The reason why the unit didn't power up is because of the following reason.
    > The power supply board was missing output voltages, you have to check all output voltages for consistency. Your reference voltages is mostly printed in the board itself. If you found one check for open/shorted voltage regulator transistor, leaky/dried filter capacitor, open fusible resistor, shorted/open diode all are in the power supply board.
    > The power supply board was gone to overload triggering the over current protection circuit to avoid further damaged. Once got some dropped of output voltages in the power supply, disconnect the load and test it again w/o the load. If the voltages gone to normal voltage while the load was disconnected, this indicated that the fault is came from the load.
We have a PD-800 dvd player. & it keeps saying "wrong disc". help
unplug for 2 minutes, then plug back in. This works,If you haven't done this already, try a different disc, preferably one it has played successfully before. If another disc works, then take a look at the working side of the disc that doesn't work and check for scratches or smudges. Or, if it's a recordable disc, it may just be a brand that your player can't handle. Every now and then, I even get a factory DVD that my player can't handle.
If this is happening with any disc, even ones it has played successfully, then we'll hope for dust on the laser lens. Get a lens cleaning disc and try it. If that doesn't work, you may have to replace the player.
Sep 15, 2011 | Protron Televison & Video
I need a new casing and band as mine is corroded on the sides. Where can I order or collect? Thanks
New case is not going to happen. New band can be purchase anywhere practically unless your band is specific to the watch. Then you will have to go to the manufacture and most likely it will cost as much as you paid for the watch. There is a lot of supposition in my answer as you haven't disclosed what watch you actually have.
May 23, 2011 | Watches
My playstaion 2 wont play any discs
The eye in the tray might be scratched or damaged. This happens with age and the way the Playstation has been setting as well. It is more likely to wear out faster when it is standing upright. Try to play a movie or a game with the playstation in the horizontal way. If not the eye could possibly be damaged beyond repair.
Feb 01, 2010 | Sony PlayStation 2 (PS2) Console
I have Curtis 1046 dvd. It was playing both older and new CDs and DVD until yesterday evening, when in the middle of ALF series (old CDs with the series) it frozen, a scratching sound was coming from...
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up!
Oct 12, 2009 | Televison & Video
Xbox 360 motherboard scratch.
Jeff,
Depending on where it is scratched makes the difference. But if its small scratches I think you should be fine. However any scratch on any of these platform like things can do any amount of damage.
Replacement motherboard? You could look into microsoft to see if they sell them. However even if you do obtain one you would need to find the right code to unlock it, same parts for yours. Which will get tricky. You could try here if you think you can do it by yourself: www.xbox-scene.com
Other solution: just buy a new system, they are fairly cheap.
Jun 01, 2009 | Microsoft Xbox 360 Console
Rock found between backing plate and rooter
Chances are it didn't or won't cause any damage. After removing the rock, check rotor surface to see if it has any dings, scratches, etc
Jan 03, 2009 | 2006 Volvo S40
I have a scratch on door of new refidge - please help
Hi ibjones5474,
Dont let that scratch get ya down. It is really easy to get that scratch fixed. You will first need to buy you some appliance touchup paint. You can get a small bottle about the size of a nail polish. It even has a little brush inside like nail polish. If you get the correct color just brush a little into the scratch and viola, all better. If you have a stainless steel refrigerator that scratch is going to be a part of your life as long as you own the refrigerator. Good luck to ya and remember when you are buying your touchup you may need to order for the brand and color not just the color. Whirlpool bisque may be different than frigidaire bisque. Also you may want to practice your painting technique on a hidden spot before you jump in. Keep a clean cloth on hand also incase you have a run, just wipe it off and start again. See ya... MCA0824@aol.com
May 02, 2008 | Refrigerators
DVD won't play
Is this happens on every disc? The NO PLAY message appears when "The disc that this unit cannot play is loaded (from the user guide)". Maybe it's something to do with the DVD region? If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 18, 2005 | Yamaha DVX-S100 System
No Disc
If you sure that the system supports the disc's format.. and it wont play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 15, 2005 | Panasonic SC-AK300 CD Shelf System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
