Question about Saeco Talea Giro Espresso Machine
The red alarm light is on, not flashing, have refilled water and cleaned dredgewater, have even changed filter in water... When i push water button no water comes out of steam spout????
  • Saeco Master
  • 12,061 Answers
Hi, well what has happened is that inside the unit, a sensor has detected a "Problem", or it has "Failed" and accordingly this is inhibiting itself from working, so that an accident will not happen, often it is the pressure/water sensor, but it may also well be the temperature sensor controller as well.
The very best thing to do is contact the Agent or Manufacturer and ask them for a referral to an authorised repair and servicing center, this in the end, will be the fastest and cheapest way to effect a good permanent repair. I speak from experience here.
It isn't really practical to DIY as you see the biggest problem with any DIY is obtaining the spares and parts numbers, as one simply must have a service manual, which only the service personnel have, usually, sometimes they can be found on the 'net, to be able to get these parts numbers without which one cannot order the parts required.
Posted on Mar 15, 2011
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
I just changed my spark plugs in my 98 montero sport. Now the car won't start because the red alarm light keeps flashing. How do i fix this?
push the red light. its an alarm reset button!!! had this problem if the button is bad you will have to go to a junkyard and hope to find one because mitisibushi doesnt even stock this item!! (my button was bad!!!)
Nov 07, 2010 | 1998 Mitsubishi Montero
I have a Talea Giro and the red alarm light keeps flashing. I have refilled water and coffee and cleaned the brewer. Sometimes it will work after turning off and on again. Sometimes heats up and is ready...
Checklist:
  • Water tank full
  • Remove dregdraw for at least 10 seconds then re-insert
  • Beans in hopper
  • Beans lid correctly inserted
  • Steam knob Exactly in off position
Feb 25, 2010 | Saeco Talea Giro Espresso Maker -...
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
Aug 13, 2009 | Canon PIXMA iP1600 Printer
How to change the water filtration light from red to green?
On mine, there is a button combination that resets the alarm. Yours may be different. The bottom buttons, one left, the other on the right. Mine say "ice type" and "child lock". Holding them both in for ~5 seconds resets the alarm. Try this.
Best regards, --W/D--
Aug 08, 2009 | Kenmore Refrigerators
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water filter alarm light
without the specifc model number i beleive you hold down the button under the filter light to clear it i think its a hidden button right under the light but if not send me the model num and ill look it up
Jan 09, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Saeco Talea Giro Espresso Machine Logo
134 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
