Phoenix Bios H/D test results... #2- 07 Fail. How can I fix it?
    Master:
  • 525 Answers
May have a bad hard drive. may need to be replaced.
Posted on Mar 15, 2011
Samsung Sens X06 bios fail
see this steps and proceed .God bless you
    • 1 Download a crisis recovery program designed specifically to restore damaged or otherwise non-functioning copies of Phoenix BIOS. Read the instructions for using the recovery program to make sure that no specific changes or configurations need to be done to it before it is used.
    • 2 Place the Phoenix BIOS recovery program and its files onto a blank disc or a USB drive according to the program's instructions (this usually simply consists of extracting the files from an archive.) Once the program and its files are in place, insert the disc into the computer's drive or plug the USB drive into an available USB port.
    • 3 Hold down both the Windows key and the "B" key on your keyboard and press the power button on the computer. (On some laptop computers, you will need to press the "Fn-B" keys instead.) Wait for the disc drive light or the USB drive access light to start flickering to show that the computer is accessing the Phoenix BIOS recovery program, and then release the keys.
    • 4 Wait patiently while the Phoenix BIOS recovery program overwrites the damaged sections of the motherboard's current BIOS installation. Depending on the computer and the recovery program used, the computer may or may not reboot once BIOS recovery is complete. If the computer does not reboot on its own, wait at least 10 minutes before manually restarting the computer to make sure that you do not interrupt BIOS recovery. Eject the disc or remove the USB drive before rebooting to prevent accidentally reloading the recovery program.
    • 5 Reboot the computer and watch to make sure the Phoenix BIOS screen appears as normal. Once the BIOS loads properly, your operating system should launch as normal.
Oct 18, 2012 | Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Acer 5630G Error 07668 Password!?!?!?!?!?
try all these passwords from what you described it looks like a system disabled password and i'm guessing you have pheonix bios therefore i generated some passwords with the code you provided hopefully it helps and works
Generic Phoenix BIOS: dszqtj HP/Compaq Phoenix BIOS: wmxzjzz FSI Phoenix BIOS (generic): 826167 FSI Phoenix BIOS ('L' model): 8197 FSI Phoenix BIOS ('P' model): 1985 FSI Phoenix BIOS ('S' model): 6321543 FSI Phoenix BIOS ('X' model): 5576
Mar 22, 2011 | Acer Aspire 5000 Notebook
Laptop model acer aspire1660 when i try to enter the bios 3 times pass fail it say sistem disabled [10140] eror i forgot the pass i removed the batery from the main board but dont work pls can anione...
Generic Phoenix BIOS: vrgw HP/Compaq Phoenix BIOS: iyta FSI Phoenix BIOS (generic): 37198 FSI Phoenix BIOS ('L' model): 9941947 FSI Phoenix BIOS ('P' model): 2187164 FSI Phoenix BIOS ('S' model): 41572 FSI Phoenix BIOS ('X' model): 92876
Try all those passwords thanks
Mar 22, 2011 | Computers & Internet
What is the dafault BIOS password for Acer laptop?
Some BIOS manufacturer put a backdoor password in BIOS which always works irrespective of what password you have set in BIOS. Its a master password which is used for testing and troubleshooting purposes.your bios pass will depend on the motherboard manufacturer i.e(AMI,AWARD or PHOENIX)not by the laptop itself or the name of it..try these few pass listed below;
AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SWAMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
AMI_SWAWARD BIOS Passwords:
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
PHOENIX BIOS Passwords:
BIOS
CMOS
phoenix
PHOENIX
NOTE: All these passwords are case-sensitive and are changed from time to time by manufacturers.
Feb 21, 2011 | Computers & Internet
I can't reset Bios toshiba Te2100
start and pres F2/F10/dell.
Phoenix BIOS setup and help
http://www.pcbuyerbeware.co.uk/BIOS.htm
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
http://www.computerhope.com/help/phoenix.htm
If same as before please setup bios fail save default.and pres F10>enter
Hope this helps.
Jan 14, 2011 | Computers & Internet
I can't start my dell . how can i disable memory bios?
You cannot disable the BIOS memory, you can clear it (or more correctly reset to default). On the MoBo near the BIOS battery will be a 3 pin header with 2 pins shorted out with a jumper. WITH THE POWER LEAD REMOVED move the jumper across so that the centre and opposite pin are shorted for 5 seconds then move back to original position.
Your BIOS has now been reset to default.
If you can't find the pin out header then remove power lead and BIOS battery for 24hrs to allow the bubble memory to discharge fully for the same result.
What makes you think it is the BIOS memory stopping your system starting?
Jan 06, 2011 | Dell Dimension 4500 PC Desktop
My customer has a gateway p-171x notebook that has a bios setup password he does not know-how can I reset that? I have taken out the battery and it disn't work. It is a Phoenix bios
Sadly, many Gateways models must be returned to the manufacturer to have these passwords reset.
Try A Phoenix Backdoor BIOS Password The reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX. Try one of these passwords and see if they will unlock it.
If that doesn't work, there could be a jumper located under the keyboard if your model has one.
The last thing to try would be to open the unit and remove the CMOS lithium battery to clear it. This is of course a last resort and is not for the weak at heart. You may void the warranty if there is one by doing this, so be careful.
If I think of anything else, I'll let you know. Please reply with the fix if one of these works.
Mike Vail
Oct 05, 2009 | Gateway P-171X FX Edition PC Notebook
Need mother board driver:phoenix Phoenix - AwardBIOS v6.00PG
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer CRYSTAL_XP
Generator crystal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2010-03-04
Time 09:01
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message P4M80-M4 (4M80M609 BF)
System BIOS Date 06/09/07
Video BIOS Date 08/15/06
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Oct 11, 2008 | Intel Motherboard
HARDDRIVE LIGHT DONOT COME ON AND NOW IT ASKING ME FOR A PASSWORD AND I ENTER THE ONLY ONE I EVER USE CAN YOU PLEASE HELP ME? I HAVE NOT ABUSE MY COMPTURE
Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
Aug 13, 2008 | Toshiba Satellite A135-S2266 Notebook
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
