Question about Whirlpool Refrigerators
The ice machine is humming and won't stop. - Whirlpool Refrigerators
  • 93 Answers
Try lifting up the wire on the side of icemaker should make that stop. try that ok. later gator..
Posted on Mar 15, 2011
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
My washing machine hums and does not start it's cycle.
Possible that the INLET VALVE is humming and the valve is blocked or jammed . You can remove the outlet from the inlet valve and check if there is water flow If not tap on the valve with a soft hammer. It might release the valve and allow the flow, check also the water at the inlet and if the filter at the inlet is clogged.
Click this Link: Inlet valve
Jan 25, 2013 | Washing Machines
I changed the water filter, now the ice maker won't work.
Probably water Inlet Valve is bad and needs replacing.
Nov 27, 2017 | LG Refrigerators
Machine won't sew. Motor hums. Any ideas as to problem?
could be locked up or have a damaged part
the machine needs to be serviced
Apr 15, 2012 | Sewing Machines
Singer Stylist 513 - motor hums, won't sew
the machine needs to be check at a sewing machine shop
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
Humming noise comming from around the ice maker
If you had your water cut off to the ice maker and didn't have the ice maker turned off, it was your ice maker. You turn it off by lifting the wire arm and leaving it in the up position.
Please rate solution
Sep 10, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice mover stopped working Kenmore model 363.9557710 purchased Jul 96
Yes....I can definitely see all your posts. Sorry I don't have a solution for you. :(
Mar 22, 2017 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
