I want to reboot but i cannot bypass the normal set-up sequence
    Scholar:
  • 89 Answers
Are you trying to format your computer? If yes, you need to get the CD that came with your computer or the operating system disc you used to install the windows. Insert the disc on the CD-DVD drive and restart your computer. Watch for a Press any key to boot from CD or DVD... message.To boot to the CD or DVD, you'll need to press any key on your keyboard (like the space bar) within the few seconds that the message is on the screen.The Windows installation will now begin. Just make sure that you have a good back-up of your files before you do this. Good Luck!
Posted on Mar 14, 2011
Lan driver installed
Try uninstalling it rebooting and reinstall it taking note of the settings.
Jan 22, 2014 | Motion Computing AP42332 LE1600 Notebook
Reboot with cd
Put the cd in the drive and the system might be set to boot from it automatically.
If not, Put the cd in the drive and watch your screen for which key it says to hit to change the Boot Order or Boot Sequence, when you see the message, hit that key. This is a temporary change only good for the current boot cycle.
If you want to make a permanent change to the boot order or boot sequence, reboot your system and watch the screen for which key it says to hit to enter the Bios or System Setup. When you see the message, hit the key. Tab over to change the boot order or boot sequence. Normally you would make the CD/DvD drive 1st and the Hard Drive 2nd, because if the hard drive fails or has a problem you can always insert the cd and it will boot from it first. Just make sure when you boot that there is no music cd or movie dvd in the drive or you will get a message saying something to the effect of Unbootable device.
May 14, 2012 | Computers & Internet
How should the BIOS be set up?
This is the recommended way to do it.Turn on your computer and press F2 to enter the system setup. If you have problems with the Bios you have to get a Bios upgrade by getting software from dell then you can do the following.Reset the boot sequence to boot first from the floppy drive or the CD drive (depending on whether your flash BIOS update is supplied on floppy disk or CD).Insert the flash BIOS update floppy disk or CD, and reboot the computer. The computer updates the BIOS and then automatically reboots. mmediately press F2 to enter the system setup program, and reset the boot sequence to the normal setting. Then exit the system setup program.
Jan 09, 2012 | Dell Latitude C640 Notebook
MAGELLAN GPS 1412 STUCK ON SYSTEM SETTINGS SCREEN. The GPS worked fine yesterday, I took it out of the vehicle to bring it inside to program a trip, the battery was low so I took it back out to the...
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 16, 2011 | Magellan RoadMate 1412 Car GPS Receiver
My computer does not let reboot in none of the reboot options?hdd,cdrom,patition none of them wats wrong?
Must have messed up the CMOS reboot sequence. Enter the CMOS menu screen. Go through the menus and look for "Boot Sequence", and set this to your primary HD for now.
Once you get your system up, you can change the Boot sequence to CDR first, followed by HD.
Jul 06, 2010 | Dell (002TR) Motherboard
When I turn on my computer it goes to either choosing safe mode,
There are many reason for a system goes to safe mode directly.here is the solution to solve the issue
Follow the steps:
Immediately begin tapping the "F8" key when the reboot sequence begins (make sure your "F Lock" key is activated.) Once the black "safe mode" screen appears, then first try selecting the option "Start Windows Normally" using your mouse or keyboard up and down keys. Allow Windows to boot, log into your profile and wait for the program to fully configure. Once that is completed, go to the "Start" button and select "reboot." If all is well, the "safe mode" will not reappear.
If that fails, then repeat the reboot sequence -- tapping the "F8" key repeatedly -- and when "safe mode" reappears, choose the "Last Known Good Configuration" selection and allow it to go through the same sequence as in the above paragraph.
If the above does not work and your system continues to first boot into "safe mode" it is possible that a setting in the boot configuration file is checked.
For that go to start -> RUN and Type in "msconfig" in the provided box and hit "enter." The "System Configuration Utility" will appear. Using your mouse or right arrow key, select the "BOOT.INI" tab. Look for the "boot options" section and the "SAFEBOOT" selection box. If it is checked, uncheck it, select the "Apply" button and then "OK."
Go to the "Start" button and select "reboot" and your machine should now boot directly into Windows.
Mar 17, 2010 | ASUS Eee 4G Notebook
I'm having problem about my Hp desktop...
go on BIOS setting and change the booting device sequence. system hard drive make it first in booting sequence.
Mar 25, 2009 | HP Pavilion a1610n PC Desktop
How to bypass a park switch for a jensen model VM9212N
go to settings menu, and highlight language button. and on your remote enter 543210 in sequence. then another menu will pop up. Go to the settings menu and then the second one down will be the brake option. then click which setting you want
Feb 15, 2009 | Jensen Car Audio & Video
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
Stuck on Red
Normally mean fatal error on this machine you can hold the go button down for a couple of seconds and it might give you a secondary light sequence. Normally if the red light is on and nothing happens the most common fault is the fuser unit is not warming up.
You will have to replace the fuser unit, but this all depends on the second light sequence.
Thanks J
Nov 14, 2007 | HP LaserJet 2200D Printer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
