Question about RCA RP3722 Clock Radio
We had a momentary power failure (breaker tripped). Once power was restored, the radio works but the clock does not. No display at all. Any idea?
    Master:
  • 525 Answers
It sounds like the outage caused a surge in power and damaged your clock. I recommend connecting all your equipment to surge protector power strips.
Posted on Mar 15, 2011
I have a jenn aire JGR8875RDB oven. The control panel is partially out. The numbers beep. The clock displays and all the oven controls do NOT work.
Go to the power panel of your home and locate the circuit breaker for the oven. Turn this breaker on and off several times then check the oven controls. If this restores normal operation, then I would replace the breaker. If the breaker trips instantly every time you try to reset it then suspect the heating element and the thermostat. When a heating element shorts, it can ruin the contacts inside the thermostat.
Aug 07, 2016 | Ovens
The main and top oven are not working.
Check the circuit breaker in the power panel. It will be two breakers with their handles joined One of them has tripped internally. This removed 220 but not 110 for the clock and light. You can try resetting the breaker, but if it tripped internally, then best practice is to replace it.
Jul 09, 2016 | Hotpoint HAE60KS Electric Cooker, Black
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
House power tripped After power restore all the
You might try turning off power to it by flipping off the specific breaker that serves the unit. Leave it off for 2-3 minutes, turn it back on and see what you've got. If you have a manual, it could be there is a reset button, but I have no idea. . .
Oct 21, 2013 | Whirlpool Kitchen Ranges
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
How do i set the clock on jvc rv b90?
Hello
To adjust time:
1 Set the power button to ON
2 Press the CLOCK button 3 square cloumms will blink
in the display
3 Set to 13:15 by pressing the DOWN/UP
buttons
(When the button is kept pressed, the minute/
hour indication changes continuously.)
4 Press the SET button; the time will light in
the display
To set to the nearest second...
Press the SET button when you hear the time
signal from a TV or radio
To confirm the time while listening to a CD
or radio broadcast
Press the DISPLAY button briefly on the
remote control unit. Press it again to return to
the previous display
If memory back-up batteries are exhausted
or not installed, and the power cord is plugged
in again after being disconnected, or power is
restored after a power failure, "CLOCK" will
blink in the display. Set the current time again.
Jul 04, 2011 | Audio Players & Recorders
Error code 61 on remote m#lc340cp
from your description it sounds like this only happened once .. if it happens over and over then there is a different solution ... if the system is shut off then back on right away it will sometimes trip the breaker . this happens often when you have a momentary power failure ... any time the unit is shut off you should wait for a minute before turning it back on .. that allows the internal pressure to drop so the compresser is not trying to start with a full load ..
Aug 20, 2009 | LG Art Cool LA121CNP wall/window Air...
RCA RP3722 Clock Radio Logo
160 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
