Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Had it looked at and I need the ignitor. The number on the part is 0763-3
    Brigadier General:
  • 4,736 Answers
You can find the part you need at the following link. http://www.allproheaterparts.com/
Posted on Mar 14, 2011
Ingnitor glows bright yellow or red but oven doesn't light
Hello, welcome to FixYa.
Based on your description,I`d suggest it is the hot surface ignitor for the bake burner that is likely the problem...even though it glows, I'll explain further below.
Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined. It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
NOTE: Some ranges have an upper broiler the same as the lower (bake) ignitor ( some do some don't ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
Here's a helpful link...
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/316489400/1197384?modelNumber=790.71402700
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case. Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however. (Ignitor may glow but not have sufficient amperage to open valve, or open the valve slightly, even intermittently...but not hot enough to ignite the gas).
As far as checking them you don't actually need a clamp on (though it is the preferred method) you can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake ignitor. The number I use in most applications (it's fairly universal and replaces both long and short ignitors and works in 90% of ranges out there)... is part #12400035.
I would still double check with your model number with the part`s professional`s if you're more comfortable with that.
Hope that help`s. Let me know if I can assist you further or if anything is not clear and good luck.
Thank`s for visiting "fixya" for your repair needs. Please take a moment to rate the assistance you received here and a brief testimony is also appreciated.
Regards,
Macmarkus :)
Oct 30, 2011 | Frigidaire FGF326AS Gas Kitchen Range
Bake mode would do nothing. replaced ignitor which looked burnt. still does not light. ignitor does get slightly worm. i checked voltage to ignitor and i got 108 volts.
with a new strong ignitor and proper vac to it the gas valve is sticking and wont open,but to be sure tell me exact model number and the part number of ignitor so i make sure it was correct one(if looks just like old one gas valve seems likely problem)
Aug 10, 2011 | Ovens
IT TAKES A LONG TIME TO REACH 350 DEGREES ON MY JGB920 GE STOVE
most likely you have a bad ignitor,remove the racks,remove the floor to the oven,remove the flame spreader,put the oven on 350,if the flame doesn't lite within 40 seconds you have a bad ignitor.i looked up your model number,it shows a round ignitor but when i look up the part number it shows a flat ignitor,call your local parts store,give them the full model number that's on the machine,open the bottom draw,look at the left or right side of the frame around the draw opening not on the draw and you'll see the model and serial numbers,give them the full model number and they will give you the correct ignitor,let me know how long it takes before the flame lites
Nov 29, 2010 | GE Profile Spectra JGB920 Gas Kitchen...
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
Oven does not work, no gas smell. The stove top still works. What is it??
most likely you need to replace the ignitor,open the oven door,remove the racks and the bottom floor and you'll see the ignitor,put oven on 350 and the flame should lite in around 30 to 40 seconds,any longer you have a bad ignitor,open the draw under the oven door and look around the opening and you'll see a tag with the model and serial numbers.call your parts store,give them the model number and they'll give you the correct ignitor.you can check with a meter first to see if the ignitor is bad but this is a common problem,a spill over or just from normal use can damage the ignitor.
Sep 26, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I need a authorisation code for photoshop cs3 mac
you need to call adobe tech support as the activation number is valid only for 15 min though i give you a auth code it will not work for you
and i checked the srno its an invalid srno
Jul 01, 2009 | Adobe Computers & Internet
Want adobe photoshop cs3 cd key
try these 1045-0763-0757-6058-8348-7560 1045-0503-6389-9844-7659-8527 1045-0733-3390-5137-4998-4549 1045-0145-0793-4716-9972-1853
Apr 22, 2009 | Adobe Photoshop CS3 Full Version for PC
Need a new ignitor for a gas double oven
Go to www.searspartsdirect.com and enter in your model number then work your way to the ignitor .. but here is a link if you want a little shortcut there
Mar 29, 2009 | Ovens
I need codes for my direct tv box and rca tv .vcr/dvd combo
MAGNAVOX ................................ 0247
DIRECTV .......... 0863 0864 0564 0763
................. 0963 0259 0260 0263 0962
....... 0664 0065 0265 0465 0765 0866
....... 0966 0367 0567 0362 0563 0765
Dec 27, 2008 | Philips PM3S Remote Control
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
