Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have today purchased 2 X 4GB USB 2.0 Flash Drive. I assumed (not being the most computer minded person in the world) that I would just have to plug it in and then download my photos but I don't know where to plug it - can't find a **** of the right size. Do I need something else to make it work - the man at P-C World didn't tell me I would need anything else even though he must have recognised that I hadn't got a clue what I was taling about. Can you held please.
  • redmondval Aug 05, 2008
    Fixed - Thanks
    Problem Solver:
Your PC should have at least 2 slots in the back that look like the female part that would take the USB "male" part. Connect the two and give your PC a chance to recognize it. Once it does a few things may hapen (1) it will "autorun" and offer you a menu of items to chose from or (2) it will show up as a drive letter when you double click on the "My Computer" icon. You can then copy your photos to the new "drive" letter.
Good luck. Let me know how it turns out.
Father_Moe
m_greenberger@bigfoot.com
Posted on Aug 04, 2008
Why won't Viking Professional Plus embroidery disk manager save to an external floppy:
I'm a bit confused as to just what you have and what you're attempting to do with it.. If you're truly trying to use a "floppy", you have to keep in mind that a floppy will only hold about 1.4 MB. That's equivalent to about one small to average digital picture. That compares with a regular CD disc holding about 700 MB (like about 300 pictures... In today's world of digital storage, floppies are mostly worthless., even though there are a few computers left out there that have a floppy drive... Hopefully, you have a CD drive that will write to disc.. If not, perhaps you can use a flash drive (available at Walmart) to store stuff on.. I hope I've helped a little bit...
Jun 04, 2014 | Computers & Internet
Deleted new files from my flash drive
If you erase the files, (SanDisk backup and security system files) it will still work but you can not use the backup system on the drive.
Dec 14, 2017 | SanDisk Cruzer Glide - USB flash drive -...
I have a sandisk disk on key with a 4gb memory capacity. it currently has NOTHING stored on it yet says i only have 1.45 gb free. how do i clear this up? is there a way i need to format...
Hey gita! Formatting a Flash drive is really simple! Assuming you're using Windows, plug it in your PC and go to My Computer. Right click on the drive and press Format. You can choose either Quick format or normal format(Quick format does it really quickly but it may not yield best results). After that simply press Format and wait for it to finish.
You should have formatted your Flash drive and have your original 4GB of space restored!
Keep in mind that you may have less than 4GB(about 3.8-3.7) This is because formatting writes instructions to the flash drive.
Have fun :)
Aug 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
My HD was having problems staying conected through the USB. I would have to force upward to get a connection that would last on my computer. After a while the whole USB connection on the HD disconnected!...
I am assuming a few things here, so keep that in mind.
I suggest that you go purchase a hard drive external enclosure for your drive type. They are relatively inexpensive, say, 20 to 60 dollars. You can get them from Amazon, NewEgg, and many other online retailers. Go with a site that you trust and has a good return policy. You could also just drive down to your local Walmart or BestBuy and pick one up too (you will pay a little more).
Most external USB drives are simply an enclosure with a "normal" SATA hard drive inside, some hard drives are 2.5", some are 3.5" in size. You should also consider the speed of your computer's USB ports (2.0 or 3.0) when purchasing your new external enclosure.
Once you purchase that, you will need to remove your hard drive from the broken enclosure. Usually, there are just a few screws holding it together. Be aware that sometimes they cover the screw holes with stickers. Remove the hard drive and install that into your new enclosure. Your data should all be intact. Try this using the same computer or the same operating system to verify your data.
I hope this helps. :)
Richard
Nov 16, 2017 | Iomega Prestige 500 GB USB 20 Hard Drive
I just purchased a 4GB flash drive. It says that it cannot detect an Internet connection, but I am connected to the Internet. Is something wrong with the flash drive?
Assuming you are plugging this into your computer? Flash drives do not connect to the Internet. They are a storage device. Your computer may coincidentally have an Internet connection problem and is displaying the message (in a balloon, bottom right corner of screen) but it is not the flash drive it's referring to. Check your computer's network connections.
Feb 18, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have purchased a new one Kingston 16GB Data traveler 101, but this not working . How can you solve my problem. pksharmadps@yahoo.com
Insert it into the USB port, at rear of your computer or if you are using a laptop try different ports.
Now if your computer/laptop works with other USB devices, then we can assume that USB Support has been enabled in the BIOS/CMOS.
Double click on My Computer while the USB drive is in your computer/laptop. Right click on the USB Drive and select format. If you do have information on your drive it will be lost!!! Do a backup first.
Format your drive using either FAT32 or NTFS, if NTFS is available then use it as it is a better Allocation table format.
If this procedure can't be done, navigate to the control panel and Double Click Administrative Tools.
Now double click Computer Management. Under the storage field, select disk management.
Select your USB FLASH DRIVE, Right Click and select format.
Your drive should be ready for use.
If it is still not detected you could try it in a friends computer/laptop.
Alternatively you can take it back to the company/person that you bought it from as it may fall under warranty/guarantee.
Best Wishes!
Thanking you
damnor01
Dec 16, 2010 | Computers & Internet
How do I set up a built in webcam without a cd drive?
Assuming you have no CD drive at all, the easiest way would be to get to another computer with a CD ROM drive copy the files to a USB flash drive and install the drivers from that.
Hope that helps?
Dec 08, 2009 | Logitech QuickCam Communicate STX Personal...
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I just purchased an 8GB USB 2.0 flash drive from SanDisk Cruzer. I plugged it in, it recognized it then opened to documents what do i do next?
You use it like a floppy disk, you can copy files to and from your computer to the flash drive,then take the flash drive out and the put into another computer to share, ie. to download and copy files to from other computers such as a friend's computer. The files can be anything, music, photos etc.
Sep 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
49 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
