SOURCE: Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
SOURCE: our bosch dishwasher is not
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
SOURCE: I have a Bosch 18v
you have a bad battery (defective) take the unit back to where you bought it and hopefully they will understand and exchange it out for you. If the dealer won't help you can contat the Bosch company, they typically will do an exchange even if you dont' have the receipt, (a courtesy exchange). You may have to pay to ship the defective battery to them. If you can prove when your purchased the system you will have less difficulty convincing them to give you a new battery. good luck with this, my experience with Bosch has been that they are a customer friendly company and should be willing to help you,as I would hope your dealer would
SOURCE: Bosch CCS180 18V lithium cordless
Hi ramzemail,
Welcome to fixya!
It sounds like the wire connection where you insert the battery is loose. So, when you give the battery a shove in, the connection tightens, then the vibration from use loosens it again. You would have to take the hand grip piece apart until you can see the wiring and check the connections.
Here is a diagram to help you disassemble the unit: http://www.ereplacementparts.com/images/bosch/CCS180K_%283601F6H010%29.pdf
Copy and paste this entire address into your browser and the diagram for CCS180K will open for you. Should your model be the CCS180B, use this address: http://www.ereplacementparts.com/bosch-ccs180b-3601f6h010-18v-litheontrade-612-circular-saw-parts-c-128_1138_15136.html
The battery area is the same for both but, in case you ever need parts, I'll give you both.
Good luck.
Hope this helps. Please place a vote when you accept this solution. Thanks,
Handie Andie
SOURCE: bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
