Question about LG VX9600 Cell Phone
Calibration Questions. DO you tap the targets in the center or hold them down. Whne I tap it beeps, but does not move right away. If I hold it, I can not see if it moves to the next area?
  • Emon Jul 01, 2013
    i trying long time but does not aligned screen
  • 341 Answers
You just tap the targets in the center. If you tap correctly, the target will automatically move to next position.
Posted on Mar 14, 2011
  • Emon Jul 01, 2013
    i tap correctly the terget but not aligned why?
Touchscreen not working.
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
Nov 24, 2013 | Acer Aspire Z5600 PC Desktop
On the screen of MP826 a message appears it is -touch the center of the target and hold for one second. repeat as the trget moves . i try this but nothing happens .
This is the screen calibration utility. Your screen may of become really bad out of calibration. It may take a few times to get it to fix itself before you can use it. It may also help to use a stylus
if you have large hands.
Apr 27, 2011 | Coby MP826 MP3 Player
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
Trying to calibrate labels on E4205 and having trouble, if I'm reading the instructions right, I'm supposed to hold down the F2 button and it will automatically calculate via a sensor, but it doesn't. What...
Hope you found a resolution to your issue by now, but if not, there was a firmware update meant to address calibration issues. You can also do an empty calibration where you remove the media and hold the feed button until the platen roller turns, then load the media and do the quick calibration where you press and hold the feed button. I have also found that moving the media sensor towards the center of the media sometimes helps. You can also try moving the media sensor, do the Empty Calibration, then the Quick Calibration, tehn move the sensor back and do both calibrations again.
May 11, 2010 | Datamax Office Equipment & Supplies
Screen calibration doesn't work on Leapster 2. Touchscreen doesn't function properly. Used calibration technique and it still wont work. New Leapster, purchased at Christmas.
CALIBRATION - summary of hints from here that eventually got our circa 2007 green leapster's screen recalibrated - in no particular order: 1) "home+hint+B" to get started, 2) "A" button next, 3) cleaned dirt from the gap between the plastic and the screen all the way around with a toothpick (seemed to be the KEY ELEMENT to get everything else to work), 4) be patient and keep trying until you see the targets - the first one should appear in the top left corner while the text is still on the screen, 5) if it doesn't work just right the first time try again, 6) unit should beep each time you press a target center.
Mar 29, 2010 | LeapFrog Leapster Electronic Book:...
How do you set a center point scope
the way i tell the guys to set there scopes up is this,,,first clamp the gun in a gun vice, fit scope or in your case a center point,,,aim at the target down the barrel then fire the rifle at target card,,,(a big one) at no more than 20yds away, look for the strike mark,,,and without moving the gun at all, after firing the first round, move the scope so that the cross or center point is over the hole in the target,,,then repeat this lot again till you have the bullet hitting were you point the cross, all you need to do then is move the target back and lower thee point of aim on the scope as it should be shooting at the moon
Nov 10, 2009 | Crosman Optics
I found message ' tap the centre of the target repeat as the target moves ' in samsung d980 how can i solve this problem thanks
Hello!
Dont worry about it , it's just the calibration wizard.Tap the centre of the target (the cross) with the touch pen (you'll have to do it more than once befor finishing the calibration)
Oct 21, 2009 | Samsung SGH-D980 Cell Phone
The screen seems locked in one mode
im not to sure if this works with what u got but it should. soft reset: pop out the battery from it wait abit ant then pop it back in turn it on if it still does this then..... hard reset: look at the back of the phone for a little round button to push use like a paper clip or pen, hold it down and the power button down as well until the device powers on. u will loose all ur data on the phone but it shouuld work. if it doesnt then its ur hardware not the software. somewhere they repair cell phones like celltek would be able to for good price.
Jan 12, 2009 | Handspring Visor Edge Handheld
The 'target' section is stuck and I cannot get on to the Home icon, i.e. where it says 'tap exactly on the center of the target' - when I do that, the target just jumps about but I cannot return to the...
Hi:You try to tap at least the four or five times in the white screen?? When you want to go to the main menu, press and hold the center button.
Oct 15, 2008 | Computers & Internet
Leapfrog leapster hand held console
Had the same problem and no target. Wait after it says touch the center of the target for at least 5 minutes maybe longer and suddenly it will beep and appear. After touching each of the 5 targets as they move from corner to corner and then center the stylus and touch screen once again worked.
Art
Jan 08, 2008 | Video Game Consoles & Games
LG VX9600 Cell Phone Logo
131 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
