Question about Bushnell 612 x 3" Go To Reflector Telescope 76mm 50% OFF FREE UPS
The nut on the inside has fell off,which lets the telescope move around freely. whattodo?
  • 3,186 Answers
You can contact their repair center here--
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Mar 15, 2011
My husqvarna 435 clutch cover came off while cutting, chain wont spin freely when re assembled
That should be all that was there. If it's a fairly new saw, it could just fit tight. Not that I recommend this, but leave the nuts 1/2 loose. I had to get my chain moving using a pair of welding gloves and pulling it around the bar. The whole thing seated properly & I finished tightening it up. the brake fits tight but you don't want to lubricate it or it won't function properly when you need it. Also be sure the brake ISN'T engaged when you reassemble and when you're finished. Hope this helps.
Nov 07, 2013 | Husqvarna Garden
Focus knob problem
The focus knob is not supposed to feel like that. On my Celestron it had almost become detached from the focus lever which attaches to the main mirror inside the tube. There is a threaded shaft and locknut which had become loose.
If you feel DIY enough, and you understand about corrector plate centering, follow this
http://ngc1514.com/Celestron/disassem.htm
and tighten the locknuts on the threaded shaft. There is also a lot of stuff on CloudyNights (above) regarding this subject.
If not 100% confident a better idea is probably to have a telescope tech do this for you. Shop around your district.
Jan 21, 2012 | Celestron NexStar 4 SE Telescope
Loose nut inside telescope
Yuck! This is probably the primary mirror shaft nut. If you don't do anything it will eventually come off and smack the primary! This is not for the faint of heart. You must remove the corrector plate, reach down and CAREFULLY tighten the nut back up. The corrector plate is oriented to the primary. The manufacturer sorts corrector plates to mirrors. Before you remove the corrector, use masking tape to mark the exact placement of the corrector.(put the tape on the plate and the housing, then slice the tape at the edge). Might as well flock the inside of the scope while you have it open. It will increase contrast!
Dec 25, 2011 | Celestron NexStar 5 Schmidt Cassegrain...
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
I have a Leica Televid 77 with a 20x - 60x zoom ocular. The scope fell over and now the zooming knob is difficult to turn. The zoom does still work, it is just much harder to turn than before. The...
Yes you bent the shaft on the knob or the gears inside the focuser. Order another complete focuser from Leica.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 01, 2011 | Leica Televid 77 (60 x 77mm) Telescope
I installed the front wheel after having a repair done, now the wheel does not turn freely. I checked the brake, it is clear. I applied axle grease to the inside on all moving parts. If I loosen the nut...
check that the speedometer gear is properly engaged with the hub. The speedometer receiver has two fingers on it that must fit correctly in the hub. Otherwise it binds up the wheel.
Jul 06, 2011 | 1997 kawasaki VN 1500 Vulcan Classic
Hi, Original focus knob fell off my atx 70 and now the 'focus rod' goes inside the telescope instead of moving front part. Is there any way to fix it?
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
Apr 06, 2011 | Meade ETX-70 (240 x 70mm) Telescope
Battery connection
Hopefully you pulled out the ones that simple plug back in! -- check out the Mighty ETX web site for disassembly instructions--
http://www.weasner.com/etx/menu.html
Mar 19, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
One front wiper not working on Outlander 2003
if you open the hood look towards the base of the windshield, you should see the linkages for the wiper arms. make sure the linkages are all in-tact and nothing fell off. if the linkages are all good, see if you can move the passenger side wiper with your hand, if it moves freely or with little resistance check the nut/bolt that hols it on at the end of the wiper arm. see if the nut/bolt is loose. tighten if needed. also you can remove the nut/bolt and check the splines on the wiper arm where it presses onto the stud and see if they are wiped out.
Feb 19, 2009 | 2003 Mitsubishi Outlander
My wife got a BUSHNELL 78-9512, inside lense fell out
Here is a manual for a typical refractor style telescope---
http://www.bushnell.com/customer_service/manuals/telescopes/78-9512_Deep%20Space.pdf
Jan 01, 2009 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Bushnell 612 x 3" Go To Reflector Telescope 76mm 50% OFF FREE UPS Logo
35 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
