Question about Dryers
When the drum spins with a large load of clothes a thumping sound and a high pitched squeal is heard
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Mar 14, 2011
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Loud noise during rinse cycle
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Frigidaire Washing Machines
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
It has been making banging noises and the drum is sqeaking.the wash programme stops mid cycle we have drained it and cleaned the filter, it is a bit better but is still not working properley.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  6. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | AEG Washing Machines
High pitch whine when start button is pushed. Tumbler not moving
The high pitch sound you describe sounds to me like the motor is running but the drum is not spinning.
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 14, 2009 | Kenmore Dryers
Load squeal when it in the agitation cycle.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
77 people viewed this question
Top Dryers Experts
