Question about Stoves Heating & Cooling
Vermont casting encore/can't control temp taped over damper in back/runs about 400/gaskets have been changed for the most part
    Brigadier General:
  • 4,736 Answers
I'm very familiar with VC products. And I hate to sound stupid, but I can't figure out what problem you're having. Could you be more specific? Especially, about the "taped over damper in back."
Thanks
Posted on Mar 15, 2011
VERMONT CASTING 5000 NEEDS NEW BELLY PAN WHERE CAN IT BE PURCHASED
Vermont Castings only sells through its dealer network. I've provided the link to their dealer locator page:
Vermont Castings Find Local Dealers
Jul 29, 2016 | Vermont Casting Grilling
Replacing ignitor electrodes on vermont castings grill
They are screwed in, you need to remove the screws and they slide out
Jun 26, 2013 | Vermont Casting VM450SSP Grill
I NEED A SERVICE MANUAL FOR MY VERMONT CASTING RADIANT GAS STOVE MODEL RMV40
This should get you to the right manual for the rnv40 Vermont Casting located in conneticut 1-855-415-0071 8am to8pm EST
Nov 17, 2012 | Grilling
How to install a damper on a Frigidaire side by side
Installing the new damper control takes just minutes. The replacement damper control comes with a foam mounting gasket. Remove the paper backing from one side of the gasket to expose the adhesive; press the gasket to the back of the damper control. Now that the gasket is mounted to the damper control, you can mount the damper control to the freezer wall. Peel the paper backing off the other side of the gasket and press the damper control to the mounting area. The wiring harness and thermistor attach to the right side and bottom of the component, respectively. Replace the damper control cover and reinstall the removed mounting screws.
Mercedes wheels
May 31, 2012 | Frigidaire Refrigerators
Need a parts list and diagram for vm450ssp
As is typical with Vermont Castings, when they discontinue a model (as is the case with yours), they discontinue any reference to it (Owners Manuals, Parts Manuals, Replacement Parts, etc.) and refrer the customer back to the VC Dealer. However, there are a few parts available through online grill parts stores. But they are pretty limited.
At one time, NEX Grill was manufacturing the VC Grills for Vermont Castings. You may want to check their website for availability of parts.
Hope this helps you find what you need.
Apr 27, 2011 | Vermont Casting VM450SSP Grill
Where can I get a repair manual for a Defiant Encore Wood Stove Serial number 5350 made in 1986?
Try Vermont Castings Customer Care link http://www.vermontcastings.com/USA_customer_care.asp
If you don;t see your model there (everything is listed by Model number, rather than Serial Number). Click on the Manuals for Non Current Products.
Hope this helps.
Feb 14, 2011 | Heating & Cooling
I have a Vermont Casting (Honeywell) remote with 6 buttons. Ireplaced the batteries from the summer and it does not function. the Room Temp shows, the off signal shows and when you press the on button...
It's unlikely that you need a new remote. It simply needs to be reprogrammed with the correct code again. Remotes can "forget" the programmed codes if the batteries run down completely or if the new batteries aren't inserted quickly enough.
Reprogram the codes and it should work.
Please post back if you need further assistance.
Regards,
BElectric
Dec 07, 2010 | Honeywell Televison & Video
Heating & Cooling Logo
83 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
