Question about Promise FastTrak TX2300 SATA PCI Adapter, Retail (NEWITEM58866369) Storage Controller
FastTrack tx2300 bios will not boot - Promise FastTrak TX2300 SATA PCI Adapter, Retail (NEWITEM58866369) Storage Controller
    Master:
  • 525 Answers
Try using a different card with the same kind of slots if it works then your storage controller card is bad.
Posted on Mar 15, 2011
When my soon put his pennsylvania flyer train set he unhook the wiring to the fasttrack itself. How to we put in back on the fasttrack?
turn the terminal track(where the wires were connected) over,
you should see 2 screws where the wires were attached.
loosen the center rail screw, strip the wire with the red end back - 1/2 inch on the end that was attached to the screw, place wire around the screw & tighten. repeat with the other wire attaching it
to the screw on the outside rail where it was previously attached.
reconnect the terminal track to the rest,connect to your transformer
and play with your train.
Dec 11, 2014 | Crafts & Hobbies
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
I can record voice, but not guitar. I see the signal for the guitar, but just not recording. I following the same directions I would for voice but does not work. Any suggestions? Thanks
There is a button on the front that switches between XLR and 1/4" inputs. Make sure that your mic doesn't require phantom power, as the FastTrack doesn't supply the right voltage.
Mar 14, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
You will need to download the drivers on to a floppy disk. When loading setup press F6 when it asks if you want to use third-party RAID controller.
You can get the drivers from the below link
http://www.promise.com/support/download/download2_eng.asp?productId=136&category=driver&os=0&go=GO
Oct 25, 2008 | Promise (FASTTRAK TX2300-5PK)...
Missing driver raid
I have the Soltek SL-865Pro-775 motherboard and the driver CD that came with it when I built my computer. If youneed any of the drivers, let me know. teledrew@yahoo.com
Jun 20, 2008 | Soltek SL-865Pro-77 (SL-865PRO-775)...
Promise FastTrak TX2300 SATA PCI Adapter, Retail (NEWITEM58866369) Storage Controller Logo
271 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
C. David Graves
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
