Question about Ovens
I have a fourteen year old parkinson cowan ovation 60 gla and only just experiencing problems with the fan oven which is regulated by the digital timer, when i put the oven on the timer fades out cutting out the fan, i hope i can still get parts for it as i am very attached to my loyal oven
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Posted on Nov 25, 2008
SOURCE: Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Posted on Dec 08, 2008
  • 8 Answers
SOURCE: Top oven does not get up to the set temp.,as set
all ovens have 3 basic parts. metal cabinet. element and thermostat. if the element is heating, even if it is only slightly it will be the thermostat. if it doesn't heat at all it most likely will be the element but can also be burnt or bad wiring connections.
Posted on Mar 15, 2011
  • 661 Answers
SOURCE: how to replace cooling fan on parkinson cowan gas
Hi paul281,
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
You need to follow the video that I have for you , by clicking on the below link :-
CLICK HERE
Hope this helps ...:) In case you have any queries , feel free to contact me.
Posted on Sep 14, 2011
Top oven does not get up to the set temp.,as set on the control knob,could it be the stat or is it something else.Regards Graham Cooker is a Parkin Cowan Ovation 60GLXa
Mar 15, 2011 | Ovens
Hi i cant find a parkinson cowan built in gas cooker
Used or brand new? In which country?
You won't find them new in shops as they're no longer made. But you *might* find a NOS (New, Old Stock) Alto GM60 from an online stockist, but the manufacturer's guarantee will be worthless and some spare parts will already be difficult/impossible to obtain. You'll also need to check before purchase whether it's for natural gas, lpg, butane or propane.
All late (approx. 1990 onwards) Parkinson Cowan models had appalling build quality and frequent electronic faults, so I strongly advise that you look for a current brand.
Aug 02, 2010 | Ovens
Lower oven does not heat up the fan and light still work it is just under three years old what could be the problem the upper oven works fine. it is a whirlpool oven
If `the fan is working o/k, then you need to replace the oven element, located at rear of oven
Please rate my solution.
Thanks.
Aug 19, 2009 | Ovens
Hello. I have an old Roper oven, model no.
The ignitor draws amperage thru gas valve which opens the bimetal valve to release the gas.Round ignitor 2.75 amps. Rect. 3.5 amps.Bottom line if burner dont fire within 60 seconds of turning orange you have a weak/bad ignitor.Hope this helps.Please rate my response :)
Jun 20, 2009 | Ovens
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
My igniter doesn't work
The battery holder is located under the cooker, on the right handside. It swivels forwards and holds two AA batteries.
Dec 13, 2008 | Stoves Premier 900GRa Gas Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
Oct 17, 2008 | Ovens
Faulty oven door
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
