Question about Rheem EcoSense by 4.2 GPM Tankless Water Heater LP Gas
BOUGHT THE UNIT IN JULY 2009 WORKED FINE UP UNTIL THREE DAYS AGO WHEN I RUN THE HOT WATER IT RUNS FOR A FEW MINUTES THEN SHUTS OFF.
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
Ask technician for tips and tricks for keeping unit working and needed maintenance.
They will gladly offer a yearly service.
3) Read manual several times to get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 15, 2011
Trying to locate a trouble shootngi guide for an electric water heater with the model #82V52-2 Serial number #RH0805255346, we bought a new house and we are not getting any hot water. Pease help
Troubleshooting Electric Water Heaters in MINUTES Step By Step Could be a few items. Depending on how old unit is will decide whether to fix or replace. HD or Lowe's sell repair parts. Caution do not turn power back on until you have purged all the air from unit. go to furthest bathtub and open hot side, let water run for 5 minutes after the last air pocket escapes. failure to do so may burn elements out and you get to start over. Be careful
Apr 11, 2018 | Water Water Heaters
Takagi t-k3 runs hot on low to med flow on high turns cold & flame shuts off
OMG 95 PSI is too high a pressure for a tankless! What was the W.C. in inches on the manometer?
Also on a T-K3 12 isn't a Code but a partial Code. You need an R/C to make this easier as counting led flashes produces wrong codes.
you'll have to find the correct code it's throwing not a partial.
And put a Pressure Reducer on this to below 60 PSI. 95 PSI is only impressive when it blows the tubing out after a few years.
Call Takagi in California not A.O. Smith in TN and they'll help someone fix this
Sep 20, 2014 | RTO Takagi T-K3 Flash Gas Tankless Water...
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
Hot Water inconsistent
Something you can do, following your fathers logic,   is to attach a hose to the drain of the tank and run water from the bottom of the tank into a drain untill all the sediment is removed (Water runs clean). This is normally done once a year as preventive maintenance  on all tank type water heaters. The logic sounds good to me.
Feb 16, 2009 | General Electric GE SmartWater Household...
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Rheem EcoSense by  4.2 GPM Tankless Water Heater LP Gas Logo
136 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
