Question about Refrigerators
Frig not cooling
A have a maytag frig model #mf 2560 HEB the frig iced up inside then stopped cooling and at the same time the freezer only cools about half of what it should
  • wendy98765 Apr 28, 2009
    Fridge isn't cooling.
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 01, 2008
Maytag Refrigerator/freezer alarm will not turn off.
check that tha fan beside the compressor in lower back is running and that condenser tubing is lint free, also check for icing on frezer back panel if so you could have a defrost problem, if all is good you may have a freon leak inside the frig walls as tubing is all metal and will rust when sitting for a long time in storage due to moisture build up from been warm outside and cool inside during normal usage in which case you may need to change the appliance at that point you will need a service call to find if there's still freon inside your frig and of coarse your control may not read the properly..
Jan 25, 2015 | Maytag Refrigerators
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
My sidebyside Maytag is not cold enough on the frig side and the freezer side the ice maker is freezing up.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 18, 2011 | Refrigerators
The freezer is icing up up and the frig is warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Frigidaire FRT17B3A Top Freezer...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
