Question about Motorola Mobility RAZR V3
Keypad keeps blinking.
I can't switch it on and when I try, the keypad just keeps blinking.
Tried charging it, didn't work.
The screen isn't on either.
Is there anyway to fix this?
Or just get a new phone? :S
TY.
  • 1,586 Answers
You'll need a new phone. RAZRs die a lot, and they start their final journey this way - with smaller malfunctions that end up leading to death. Move your contacts to the SIM card if you get the phone to function again, and go get a new one soon. This one's on the way out.
Posted on Aug 02, 2008
Key
Nokia 6600 keypad/key problem! I hope I've put this in the right section, as I'm not sure if this is a hardware of software problem I've posted it here, hope I'm right! icon_razz.gif
I bought a Nokia 6600 recently with a joystick that didn't go down. I replaced the keypad pcb, as there was a small tear in the ribbon at the bottom of the old keypad PCB. This fixed the joystick problem, but I now realise there is another problem with the phone!
The numbers 7,8, and 9 all display 1,2, and 3 when you press them. The '0' key seems to clear whatever's on the screen, so I suspect it's acting like the red end call key. It does this with both keypad PCBs installed, so I think it's another problem. Would this be the small gold contacts on the bottom of the phone, a software problem, or some other gremlin in the works?
I've had a quick search and someone suggested *#7370# to reset the phone, and someone else said it could be a keypad IC that's gone - any other suggestions? I'm at work tonight so can't get to the phone until tomorrow morning, and as the '0' key isn't working properly I can't check which software version the phone is running icon_frown.gif
May 25, 2011 | Nokia 6600
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a craftsman 13953930D garage door opener with a craftsman keypad entry. I followed the directions for reprogramming the keypad, and it still doesn't work. I've replaced the battery and tried...
First thing you need to do is make sure it is the correct keypad. If it is an older model it will not work with your opener. They correct keypad for your opener is 139.53754.
Nov 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
When i switch on my Nokia 5800 it opens but blinks all the time and when i touch on the screen it says keypad is locked and the keypad doesnot response.
The keypad is not responsing due to the keypad guard being active. The unlock the keypad you will need to move the swich on right of the device below the memory card solt
Jan 11, 2010 | Nokia 5800 XpressMusic Smartphone
W700i wont switch on--battery fine
it can be software problem, flash u mobile .
Jun 21, 2009 | Sony Ericsson Walkman® W880i Cellular...
Motorola Mobility RAZR V3 Logo
118 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
