Question about Brady Office Equipment & Supplies
I need some plastic gears for my labelizer plus
Will not go forward
Probably the gears or other parts are jammed with the plastic and sticky substance.
Make sure it is unplugged. Then see how to take some of the unit apart. Many of these kinds of units will be held together by screws in deep indentations. You will need a screwdrive of the type of the screw-head. Remove the screws and then you can split the unit apart and see what the problem is.
More than likely, it will be a matter of removing the sticky plastic jammed into the unit between the gears and or the rollers or other parts.
Jul 26, 2008 | Aurora Global AS702MX Shredder
The plastic "nut" gear that
YOU COULD TRY AMAZON WEB SITE THEY DO SOME PARTS............... BUT TYPE IN THE SERCH BAR BREAD MAKER PARTS
Feb 19, 2011 | Toastmaster 1148X FastBake Bread Maker
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Canon PowerShot SD1100IS, Error Message - Lens Error, Restart Camera
Sounds like a broken gear, or a grain of sand stuck in a lens gear.
Nov 17, 2008 | Canon Cameras
Worn plastic drive gear
Here is a link to the owner's manual... http://12.153.20.74/manuals/107705-01V.PDF. The part you need is 107713-01. You can order it online at www.masterparts.net or by calling 800-446-1446. They should have it in stock. I hope this helps.
Oct 16, 2008 | Desa International 100089 06 Electric...
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
