Question about Daewoo DSA-122L Air Conditioner
Hi im looking for a daewoo remote control model no: DR/9703L2
I have a quantum fx rem-100 remote, and i need codes for a daewoo tv
Codes to check with Daewoo brand TVs are 0038.0029,0059,0072,0019. If you wish to get more codes to Dawoo brand TVs with other brands remote controls, check this link. Not mind the brand of the remote control. Only look for codes for Daewoo with its code list.
Feb 17, 2013 | Innovage Jumbo Remote Control
How to program remote control mitzu for tv daewoo
Look up code in book for your model and program it or do automatic code search.
Nov 16, 2011 | Daewoo DTQ-14V1FS 14" TV
Code for daewoo tv
hi,
You didn't mentioned any thing about the brand and model number of the remote you have. Need the same to give you code for Daewoo tv
ok
Aug 13, 2011 | Televison & Video
Hi, I lost my code list, I have a daewod tv, I need the code for my tv, my model contol is jer321 thnks a lot
Hi
Codes to check with Daewoo TV with Jensen 300 series remote control are;
477 / 473 / 468 / 465 / 459 / 455 / 453 & 414
OK.
Jul 24, 2011 | Jensen 143307 Remote Control
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
NEED TO GET RCA UNIVERAL CODE FOR RCU704MSP2N T0 G0 TO A SHARP MODEL 13F/M50
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 25, 2010 | RCA Universal Remote Control
I am looking for universal remote codes for my one for all-access 4 model...daewoo t.v.
http://www.oneforall.com/support/manual
Select your remote control model here and look at the manual. The remote codes are usually listed towards the end of the manual.
I found a Daewoo TV/VCR Combo Remote Code, which is 1278
There are also different codes for Plasma TVs, etc.
Jun 23, 2010 | Televison & Video
I need 4 digit code for daewoo tv using the remotec remote control
Hello dennisdl,
Try one of these codes, hopefully one of them will work for your model Daewoo:
0101
1501
1511
2611
May 25, 2009 | Universal Remote Control Hampton Bay...
Daewoo DSA-122L Air Conditioner Logo
135 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
