Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Engine wont idle - Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
  • 784 Answers
Check air fuel mixitur. Check air filter.
If its still works bad give me more details.
Posted on Mar 14, 2011
Engine wont idle
Is the check engine light on?
have you checked for vacuum leaks?
Apr 10, 2014 | 2001 Ford Focus
Saturn idle
If it doesn't how would it idle? What saturn is it? Does the engine turn over? No sense in going any further until the starter motor can turn the engine over.
Dec 09, 2013 | Cars & Trucks
1995 dodge stratus stalls at stops and wont idle sometimes.check engine light not coming on
It might be the throttle positioning sensor or and idle control setting. I suspect the former as the problem. Get a repair manual to locate the sensor and replace it.
Sep 18, 2012 | 1995 Dodge Stratus
1989 wrangler 4.2 litre engine wont idle
my 1989 jeep wrangler would not idle and come to find out it was a little filter cloth inside the fuel tank that was on the end of the pickup tube going to the fuel filter. It was clogged up and when the engine was started it would just suck in and cut off fuel flow. My mechanic removed the filter cloth from the tube and the jeep runs great. It really does not need to be there because the fuel line has a filter on it. I hope this helps , I know for me it was very frustrating trying to figure this problem out.
Aug 09, 2012 | 1989 Jeep Wrangler
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
Harley engine wont idle
Your bike has an idle screw on the carb. looking at carb its on the right side turn to the right to bring up your idle.
Mar 24, 2009 | 2000 Harley Davidson FLSTC Heritage...
Wont idle
put the crank at TDC and the cam gear and TDC slip the belt on adjust the tensioner and then rotate the engine two times make sure the timing marks are still lined up then put it back together and try it if you have the timing off it wont idle right and if could also be the throttle positioning sensor
Jan 03, 2009 | 1994 Honda Accord
Engine wont idle
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Dec 02, 2008 | 1989 Ford F 250
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
37 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
