Question about Toshiba 32A14 TV
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in the right rear of the television. aside from that, just doesn't turn on.
  • Toshiba Master
  • 8,457 Answers
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
Posted on Mar 14, 2011
Hisense 55" Model # 55H6B electrical crash
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://homenol. blogspot.com/ http://electronicshelponline.blogspot.com/
Jan 30, 2017 | Hisense Televison & Video
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
Dec 01, 2014 | Sansui 50IN E-LED TV 1080P SLED5000
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Where are fuses on Toshiba 32a14 TV won't turn on
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
Feb 21, 2011 | Toshiba 32A14 TV
My led power indicator flashes seven times, when i cut the tv on it cuts back off. How do i fix this problem?
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that helps.
Nov 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 32A14 TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
