Question about RCA Microwave Ovens
I have a rca microvave model # RMW1480 I have to live the door open if closed then the fan stays on just purchased feb 2008.thanks
  • 23 Answers
It sounds like there is a problem with the door switches when the door is closed.check to see when the door is closed that all the buttons on the microswitches are all closed when the door is shut,if you have any more problems then get back in touch,regards les
Posted on Aug 01, 2008
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
GE XL 1400 Spacemaker Microwave
Clean all the visibility of the microvave which causes the light switch logged. pls consult the user manual in cleaning the oven.
may help, melnavz
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge pvm1870DMWW
Verify the door micro switches.
Aug 30, 2017 | GE Microwave Ovens
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
When the microvave in plugged into outlet it makes a buzzing sound but works ok. When the door in opened the noise stops but starts back up when door is closed.
I just had the same problem with my ge spacemaker microwave model number JVM1490bd. I removed the grill on the top of the microwave with two screws on top. There is one screw that holds the front touch pad on, remove the screw and lift up to remove. The damper assembly is on the upper left, my door was sticking and didn't make the limit switch. I moved the door back and forth making the switch a couple times and that solved the problem.
Jul 16, 2011 | GE JVM1490 Convection/Microwave Oven
My 2 years old RCA microwave oven model RMW1480. Now when you cook over 2 minutes, it will cut off power, and cause my fuse box jumped off.
your magnatron is failing and is pulling too muck current, youmay also have too small of wire and breaker for this unit or a screw has hit the power cor in the wall, or have a weak breaker
Feb 22, 2011 | RCA Microwave Ovens
Whirlpool Microwave after cooking fan on when door closed
Guess I'm an impatient person, took microwave to service center this morning. Hopefully, have it fixed by this afternoon. Thanks.
Jun 17, 2009 | Microwave Ovens
Microwave Ovens Logo
134 people viewed this question
Top RCA Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
