Question about MSI K8T Neo-FSR Motherboard
K8T Neo Motherboard with Via and Promise SATA problems
Hi, I am trying to get a bunch of single SATA drives to function independantly with my motherboard, i.e. not raided together. I have three identical 500Gb seagate SATA drives and a SATA DVD drive, but both the VIA controlled and Promise controlled connections do not seem to recognise anything. In Device manager I have two devices underneath SCSI and RAID controllers with a yellow exclamation mark - namely 'VIA RAID controller - 3149' and 'WinXP Promise FastTrak 367/378 (tm Controller'. I'm sure I just need BIOS and/or driver updates but I've looked everywhere and all threads that look promising tend to go nowhere. Any ideas, or is this a Windows re-install do you think? Thanks in advance. mike
  • 2 more comments
  • Mikiejc Aug 04, 2008
    The via drivers I have already tried and they don't seem to do much although they do install. The fast trak drivers don't even get recognised and won't install. I have unplugged all the drives and the via controller now looks like its working. I think this controller has an issue with my hard drives - I've tried inserting the jumper to limit the drives to 150mb/s but that doesn't work either. I've noticed that the fast trak controller comes up with a No Bios installed error on boot up (before windows starts) so I'm going to have to go into that in a bit more detail tonight and see what I need to do. Thanks for trying. Have you any more ideas?
  • Anonymous Nov 22, 2008
    I have the same issue when I try to connect my new SATA DVD drive. It just doesnt recognize it like it doesnt exist. I have tried VIA but doesnt seem to work at all. My thought is that the SATA plugs dont work or they were not part of the bios configuration maybe. I dont know. I am going to return this drive and get an IDE one and forget obout it.
  • chrisfinchy Jan 04, 2009
    Same problems here;
    Almost at the end of my tether with this thing.
    I have a rig with the K8t Neo (ms 6702 v1.0) and a AMD 3000+ 64 bit.
    All i'm trying to do is get the Motherboard / bios to recognise my new SATA hard drive so I can use it as additional storage and later in a new system build with the same motherboard.
    Things Tried already:
    1. Fiddling with the bios SATA settings...
    2. Jumpering the drive to 150mbps (SATA I) limit...
    3. Flashing the bios to an earlier version with SATA ROM updates...
    Can anyone please suggest anything?
    Many thanks in advance for any help on this one.
  • grumpy2001 Jan 21, 2009
    Want to istall new sata hd.I want to install winxp it does not see sata drive .What to do.
  • 781 Answers
Http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
Posted on Aug 01, 2008
  • David
    David Aug 04, 2008
    sorry If I was there could probably do so but remote analyzing is difficult
    Please leave a rating for me
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Motherboard won't recognize SATA DVD drive.
make the dvd your 1st priority in bios for boot, if it cannot be recognized try taking the floppy cable out of the floppy drive, maybe you have a problem with your power supply
Feb 14, 2010 | MSI K8T Neo-FSR Motherboard
Board is not recognizing my 80G Maxtor drive. I
with AmiBios you may be able to get it to rediscover your drive... If that doesn't work, open the case and check your IDE and SATA connections. Sounds like you have a RAID configuration with your Promise board.
Not sure I've helped, but you have some clues to check on. Probably visiting Promise's website and looking for troubleshooting may help.
If your Maxtor drive is a SMART drive, you might be able to check to see if it indeed has failed.
Feb 08, 2010 | MSI K8T Neo-FSR Motherboard
MSI K8T Neo 2 not recognize Hitach 1 TB Sata
This is a quote from VIA:
"CHIP FIRM VIA issued a note to its customers telling them of problems with chipset support for hard drives using the Serial ATA II standard.
It said that VT8237 and VT8237R chipsets don't provide forward compatibility for S-ATA II, which is important as hard drive makers are beginning to manufacture this type of drive.
But Via is readying the release of VT8237R Plus, which will solve the problem. This means that motherboard makers that use the former chipset should clear their inventory before September.
Hard drive manufacturers position with S-ATA II is as follows, said Via in its note. Western Digital and Samsung are already shipping these devices, while Seagate and Maxtor will start shipping them during this quarter.
If you connect S-ATA II drives to an old Via chipset which includes the VT8237, VT8237R, VT6420 and VT6421L, the devices won't be detected.
Some mobo makers, such as Epox, have already responded to the problem and have warned their customers to seek the support of hard drive vendors. In a letter to its customers, it said that they should also check the specs of other manufacturers' Via based motherboards."
Jan 11, 2010 | Computers & Internet
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Upgrade sata hard drive
I Recommend Western Digital (W.D) Hard Disk Drive.
Comments pass......
Drive the motherboard
This is your Mainboard driver
MSI K8T Neo V (MS-7032)
Direct Download :
VIA 10/100 LAN Drivers
XP :
Vista :
VIA PIDE/SATA RAID Drivers & Utility
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
VIA Chipset 4in1 Drivers
XP :
Vista :
VIA VT8237(R) SATA RAID Driver (For floppy driver)
XP32bit :
AMD Cool and Quiet Driver
• AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ systems with ACPI 2.0 processor performance control objects
• WinXP WHQL pass
XP :
May 08, 2009 | Intel Motherboard
SATA Drive on MSI K8T Neo MS-6702 Ver 1.0
I believe when first installing windows it asks you to press F2 if you want to load sata drivers
Have them handy and follow instructions
Sep 19, 2008 | MSI K8T Neo-FSR Motherboard
MSI K8T Neo-FSR Motherboard Logo
937 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
