Question about GE Dishwashers
GE Profile Dishwasher the Normal cycle light keeps flashing
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
ginko
  • 19396 Answers
SOURCE: GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Posted on Mar 13, 2009
SOURCE: purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Aug 06, 2009
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
SOURCE: electrolux dishwasher all lights blinking and wont
I had the same problem and followed rstecher and his solution. Removed the kick, light flashing was saying a leak was detected. Tipped the DW on it's side, have plenty of towels ready because the pan will be filled with water. Make sure power is off. Removed the pan and every single one of the clamps was loose. Tightened all the clamps at least 4 complete turns. Dried everything so the sensor wouldn't pick up any water. Put the pan back on and it worked perfectly! Thanks rstecher!
Posted on Jun 09, 2010
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
i think it means the water heater in the dishwasher is not working,or the element is shot.
Mar 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
The Normal wash cycle won't light up. Only china cycle - just bought used dishwasher.. GE Profile 5 wash cycles stainless
does the normal wash cycle work though sometimes a ligt might be gone on the control if the wash cycle doesnt work then your in for some headahces unfortunatley you would have to be able to diagnos which is the problem either the main control or the touch pad it all depends on how old the unit is ive seen both of these go you can find the part online at marcone appliance parts if you have a problem diagnosing which it is please call a technician and they will be able to tell which one is malfunctioning
Jul 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
I have a GE Profile Triton Dishwasher and it has worked fine for about 8 years. Suddenly it will not reset. The reset light blinks after reset but you can not choose a normal cycle afterwards. I shut of...
Hello, how are you?
It sounds like you have a stuck key on the keypad, preventing you to push any other key.
I've seen this problem many times in the past 4 years.
Good luck.
Ned
Sep 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Jun 11, 2008 | GE Profile PDW8400J Built-in Dishwasher
Ge triton xl dishwasher
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
200 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
