Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
  • 4 Answers
Hello!
I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
Here's what you need to do:
1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
  • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
  • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
  • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
  • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
  • HDMI >>>>> HDMI
5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
Hope this helps!
Posted on Mar 14, 2011
Acoustic solutions tv dvd
You may have to resort to disassembly to get access to the drive. If the DVD will not eject, it is difficult to retrieve it.
Oct 18, 2013 | Televison & Video
Hi, I have an acoustic solutions sp-sub woofer.It has bare wires on each end.I originally had the instructions and was able to set it up easily. I have recently moved house and cannot remember how to...
Um, if the sub has the standard speaker wire connections it will only work when connected to a single set of speaker OUTPUTS by something elctrically similar to lamp cord. I assume you have other amps for the other channels.
Some more information about the sub would have made this easier for both of us.
Jul 25, 2011 | Audio Players & Recorders
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
I NEED THE CODES FOR ACOUSTIC SOLUTIONS DVD PLAYER
the codes in the book are 0713 0730 1242 you may need to try all 3 the find which one is compatible
Jan 20, 2009 | Alba DVD-108 DVD Player
Manual for acoustic solutions lcd32805hd tv
You will need an HDMi lead running from the port on the back of your television to the port on a compatible DVD player/recorder, then toggle (keep pressing) the AV/Source button on the remote to switch the television mode to HDMi.
The HDMi port will be marked HDMi on the back of your television.
Jan 01, 2009 | Televison & Video
Silvercrest remote control code for acoustic solutions dvdrw300 !
Use learning functions to copy the code from the original remote.
Sep 28, 2008 | Televison & Video
Acoustic solutions ctvl32w3hd
the sky remote code for acoustic solutions ctvl32w3hd 1239 (its a goodmans code ) works fine on mine
Jul 17, 2008 | Acoustic Research UltimateRemote Remote...
Dvd recorder
Hi there! No!! I have not solved this problem. I have done everything from following the Manual Instructions on p.22, to unplugging the Recorder for several days and then plugging it back in with the hope that in would work, to finally, taking out the batteries of the Remote and pushing each of the buttons twice ...a suggestion that I found on the Internet. All of these solutions were supposed to return the Remote back to the default setting of DV3. Go figure! How are things going for you? I am sure that you have noticed that there are NO references for "technical support” anywhere in the Manual.  .... no e-mails or phone #'s. Any ideas where to go form here?  johnb
Jul 05, 2008 | Televison & Video
ACOUSTIC SOLUTIONS AS135 INSTRUCTIONS
Hi mike,
The television has audio out with two pins red and white. This can be connected to the input of subwoofer. and dvd player should have analogue 5.1 out put i.e six pins this can be connected to the subwoofer, but only either of can be used at a time.
ramesh22
Jun 07, 2008 | Audio Players & Recorders
Televison & Video Logo
335 people viewed this question
Top Televison & Video Experts
Electro Med Services...
