Question about Maytag MAH2400A Front Load Washer
Where can i get a repair manual for a Maytag MAH3000AWW washer?
  • 33 Answers
Repair manuals are only available for people with licenses for appliance repairs sadly.
Posted on Mar 14, 2011
  • 8 Answers
SOURCE: my washer Maytag Neptune Model
i don't remember the solution, becuase it wasn't the shut off problem I am having (mine shuts off after 5 minutes) but google search of "maytag neptune shuts off" or somesuch should find you the solution.
Posted on Oct 23, 2008
  • 163 Answers
SOURCE: maytag parts/repair manual
try repairclinic.com
Posted on Mar 06, 2009
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
  • 401 Answers
SOURCE: Maytag neptune MAH3000aww washer, will not work on
NEPTUNES HAD A ISSUE WITH THE DOOR WAX MOTOR SHORTING OUT BUT IT BURNS OUT THE MAIN BOARD.IF THE DOOR LOCK LIGHT DOES NOT COME ON REMOVE POWER THEN REMOVE SCREWS OFF THE TOP OF THE TIMER COVER AND TIP IT FOWARD. LOOK ON THE MAIN BOARD AND SEE IF YOU NOTICE A BURNT RESISTOR P-11 POSITION I BELIVE
Posted on Jan 12, 2010
SOURCE: I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Posted on Jan 25, 2010
Testimonial: "Thank you. You gave me enough evidence now to get a new washer. Any recommendations? Most reliable front loaders."
Model MAH3000AWW won't spin
As giving info it seems it needs new control board and door lock .as I could see this is very old model and parts are very expensive
May 06, 2014 | Maytag Neptune Washer Door Mah3000aww
Have an mah3000ww washer and it will go through the whole wash cycle but will not exspell water out of hose
Pump mite b blocked-filter on front machine or pump stopped working need to replace pump if filter is clear , to empty water out lay outlet pipe low down on floor and rain out so u can repair
Jan 11, 2013 | Maytag Neptune Washer Door Mah3000aww
Jan 25, 2010 | Maytag Washing Machines
Neptune MAH3000AWW washer will not drain
First and foremost unplug the unit
remove back panel
remove hoses from pump (expect water have towels handy)
open pump by removing screws
remove foreign objects if any
check impeller blades to ensure that they arent worn down
rebuild and reinstall pump
or replace pump reconnect hoses, replace rear panel
you should be good to go
Sep 10, 2009 | Maytag Neptune Washer
I have a Maytag MAH3000AWW Washer. It will start
That is a common issue that is caused by the control board of the machine. You may need to request service to fix this issue. Usually it may be caused by a resistor. Replacing the resistor may make the machine to work for a while but the repair will not last longer. I believe that the machine control board next to be replaced. Something else may be causing the control board to go bad.
Perhaps you were able to feel a burning smell from the washer machine in previous days.
Standing water may be caused by the control board failure because the pump will not operate properly.
Aug 29, 2009 | Maytag Washing Machines
My washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the "ON" led just light up 3-5 sec then turn off
my washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the led just light up 3-5 sec then turn off
Aug 21, 2008 | Maytag Neptune Washer
MAYTAG NEPTUNE WASHER SHUTS OFF (MAH3000AWW)
motor controller or motor, weigh the cost of the repair before comitting to the repair, new parts only carry a 90 day warranty
this could be a large amount applied to the cost of a new machine
Apr 11, 2008 | Washing Machines
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Jan 18, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH2400A Front Load Washer Logo
323 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
