Question about Whirlpool Kitchen Ranges
I have a whirpool range top that i purchased that i now realize i do not have 220 V circuit available (replacing a gas range top). I have 120v available. The range top has a sticker that says 'connect only to a 3 wire 120/240 volt power supply, the neutral conductor is not required for operation of the appliance.' Besides having an electrician put in a new 220v circuit, is there anything else I can do? Will it operate off of 120v? It is a whirpool rr3024rb01. Thanks
  • 33 Answers
It will not operate. The control panel will work but you will have no heat. The top and oven need 220 to actually heat up. The only thing that will work on 120 will be your clock and a warm zone if there's one.
Posted on Mar 14, 2011
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
How can i change my 220V jet pump into a 120V jetpump?
Why do you want to?
You have to change the motor to a 120v model, same frame.
Service wiring has to have a hot, neutral and a ground. You should already have three wires so that is not a problem, just have to move one of the 220 hot wires to neutral. That will give you one hot, one neutral and one ground wire to make your 120V circuit.
If you only have 120V service and a 220V pump motor you can purchase a step up transformer that will take 120V in and give you 220V out. You must know the power in watts or KVA of the motor in order to purchase the correct step up transformer.
A bit more information about your situation would help.
Aug 19, 2012 | Plumbing
I have had a P-44 oven in an Auntie Anne's Pretzels shop for 15 years. It has been connected to a 4-wire, double-breaker circuit. I ordered a new P-44 through Auntie Anne's and thought it would be...
hi...since the specification of your new oven is 208v 1-phase and since voltage rating on your receptacle or outlet s only 120v..it would be advisable for you to purchase an INVERTER, it is a step-up transformer that converts 120v to 220 v..in that way you can supply your oven according to its specification..thanks..
Jul 06, 2011 | Bakers Pride P-44S Oven
My GE PGS975 DEP1 (GAS RANGE) DIGITAL CONTROLS ARE NOT WORKING. I purchased this brand new gas range in the USA and had it shipped to Brazil. After i installed it and plugged it on every think worked...
Power supply in Brazil is not universal over the entire country. Your range was built for 120 volt, 60 Hertz power supply. If you are in some areas, you may not have the proper voltage available. 127 V found in states of Bahia, Paran? (including Curitiba), Rio de Janeiro, S?o Paulo and Minas Gerais (though 220 V may be found in some hotels). Other areas are 220 V only, with the exception of Fortaleza (240 V).
Brazil does use 60 Hetz, but if you are in an area which only supplies 220 or 240 volts, you would need some type of adapter to convert that to 120 volts for your gas range. If you connected to the higher voltage, you may have irreversably damaged the electronic control, requiring control replacement, before connecting to the proper (120 volt) supply. I would expect 127 volts to operate your range, but if the voltage varied up from that, it could damage the control. Even in the US, voltage variations of 108 to 125 are rather common.
May 22, 2011 | General Electric Profile PGS908 Range
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven and oven display do not work or light up, but stove top and over light still works
Check if there both hot wires and the neutral are ok at the control board.
You should have 110-120v between each hot wire and neutral, and 220-240v between two hot wires. If power is ok, replace control board (the display unit is on the control board).
Part numbers:
White: 74009221
Black: 74009223
Bisque: 74009222
Repairclinic.com has pictures of the parts.
Oct 14, 2009 | Maytag MER5775Q Electric Kitchen Range
I want to know if i can change the yellowish color of my stove top to white somehow and if i need to are the sides paintable to white Jean It is a tappan gas range.
You can purchase white arcylic appliance paint in spray cans. Simply use a piece of sandpaper to 220 grit to rough up the surface before you paint them
Apr 16, 2009 | Tappan TGF320 Gas Kitchen Range
Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
Kitchen Ranges Logo
528 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
