Question about Lexmark P4350 All-In-One InkJet Printer
Error1102 Invalid Cartridge, but it has been working and now I get this message without any change in cartridge.
    Scholar:
  • 172 Answers
Cartridge Error (1102, 1203, 1204, or 120F)
  1. Remove the print cartridges, and close the cartridge carrier lids.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the Error1102 Invalid Cartridge, but it - button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
  4. Error1102 Invalid Cartridge, but it - button_power_0.jpgttp://i.fixya.net/uploads/images/button_power_0.jpg" alt="button_power_0.jError1102 Invalid Cartridge, but it - button_power_0.jpg> button is not lit, press button_power_0.jpg.
  5. Reinsert the black (or photo) print cartridge.
  6. If the error:
    • Reappears, replace the black (or photo) print cartridge with a new one.
    • Does not reappear, reinsert the color print cartridge.
  7. If the error reappears, replace the color print cartridge with a new one
Please rate & vote,If you like solution...
Thanks
Posted on Mar 14, 2011
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Printer shows Invalid Cartridge but it is not?
I ran into the same problem with the same printer. At first I was able to take it out and turn of the printer. Put the toner cartridge back in and it would work fine. But recently, so such luck, ended up buying a new toner cartridge and works great. Slightly disappointed as the old toner is 3/4 full but its also very old and has been in the computer since purchase date. I notices when I took the old toner out I could smell the ink like it was almost burnt. If changing cartridge doesn't work I recommend a HP. I only use this printer for bulk prints but my HP for everything else. HP is the way to go....
Mar 12, 2012 | Dell 2335dn Multifunction Laser Printer
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
Error1102
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  6. If the error:
  7. If the error reappears, replace the color print cartridge with a new one.
Dec 18, 2009 | Lexmark C533DN InkJet Printer
Set ink cartridge / invalid ink cartridge error messages
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). for more information about reset printer cartridge .
Jul 31, 2009 | Epson Stylus Pro 4000 InkJet Printer
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
Error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Apr 27, 2009 | Office Equipment & Supplies
Invalid toner black
The issue with refills is that sometimes you get a bad one where it will do this. The only solution would be to purchase a genuine cartridge.
Mar 27, 2009 | Office Equipment & Supplies
"Invalid Imaging Unit" after replacing toner cartridge
After 2 years ,surly it need to change some part because of life time of some part that is very tired ,try to show it or take it to samsung service center in your country ,...
Jan 18, 2009 | Samsung CLP-550N Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
598 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
