Question about Health & Beauty
How to format m card on my phone - Health & Beauty
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Hello Dear
To format memory card of your phone/mobile. Go to the memory card option and Select the Memory Card Options. and then press Formate memry card.
Do not forget to rate Please.
Regards
Posted on Mar 15, 2011
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
Apr 15, 2011 | Nokia 6630 Cellular Phone
I bought a micro sdhc 4gb card to use for my phone nokia 5300. when i load the sd card to format it through my phone it would say card not formatted-operation fail. also i could not find the text to format...
Look for your phone memory card size limitation. It maybe not supporting 4GB. See the manual of it. But you can format your mmc by a card reader if you want.
Nov 01, 2009 | Nokia 5300 Grey Cellular Phone
MicroSD card problems
Try letting the phone format the card. 1) Backup the music files you already have on the card. 2) From your computer, right click on the drive representing the card and re-format the card. 3) With the phone turned off, insert the card into your phone. Power on the phone and follow the steps to have your phone format the card. 4) Now copy the files back to the card using your computer.
See if that does the trick. If not, try performing the same steps as above, but instead of re-formatting the card in your computer, go into disk manager and delete the MicroSD card's partition (be careful that you select the correct drive representing your MicroSD card). When you re-partition the card, uncheck the "format" option, which will leave the card unformatted. Then let your phone format the card.
Good Luck!
Aug 13, 2009 | Samsung SGH-P850 Cellular Phone
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Help with memory card inkrazr cellphone
Do not use card reader and format with pc, you only format the card with the phone,and only once.
If you format the card with your pc the phone migt not see the card anymore,even if you format fat32. The card is suppose to be formatted with phone because the phone needs to build folders in the card.
As for saving anything,say pic,just open options and choose card.
Apr 13, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I bought a new mico sd card for my nokia 6233 bu it keeps sayin memory card not formatted hw cani format it
Dear
There Are two ways to format sd card
1) by Phone : Go to Memory card option
Gallery - memory card - option - format
& ur card will be formatted
2) By pc : connect ur phone to pc or sd card reader & right click on removable disk which is your sd card's slot & select format option.
Then it will ask for custom & quick format, select one from them & ur card will be formatted
Thanks & regards
Feb 23, 2009 | Nokia 6233 Cellular Phone
My N73 music editon can't format the memmory card
format your memory card first in your pc...after that format your phone by entering this code in the main menu..*#7370# after that format your memory card on your phone...then try installing application on your phone...hope this will help you...
Feb 12, 2009 | Nokia N73 Cellular Phone
MOTOROLA RAZR V3 SD CARD? SANDISK.
Did you format this card with your pc first, you should not have, is the card under 2gb,the phone can not handle a 2g card or over,,
now if you did not format the card with your pc and it is under 2g,you can now try to format card with your phone, it will not be able to use the card until it is formatted with the phone,,if this does not work then try formatting the card with pc then try it again with phone.
Dec 30, 2008 | Motorola Mobility RAZR V3
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
V3i card formating
no solution... need a 512kb sdmini card... that is the MAX supported size.. i have the same thing on mine... i had a 512 card tho and it formats fine and works. the 2gb card wont even be recognized by the phone..nevermind format. i can also format it on my pc but that does no good
good luck
512 sd cards are 5 bucks on ebay now ! get one
or two
Nov 04, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
