Question about Dell OptiPlex GX260 PC Desktop
I have a dell optiplex GS260. It comes on to the a black screen stating windows is unable to start properly, the options are to start in safe mode, with command prompt, last known working config + start normally. When I attempt any of these options it states error windows could not start because the following file is missing or corrupt: windows/system32/config/system it also says you can attempt to repair this file by starting windows setup using the original setup CD-ROM. I do not have the origional disc however I have used a copy which I burned as an ISO image file of windows xp with service pack 3 and also a copy of windows 7 home premium and none of these are working. I have attempted to boot the system from disc and that also does not work, please help
    Master:
  • 515 Answers
Did you boot from disc by pressing F12 when you see the logo and select boot from CD? I would suggest you to enter system setup by pressing F2 and check which one is the option choose for your hard disk or HDD if it displays like that. Make sure it says single SATA or IDE disk. If you are not sure where to see, you may choose to restore the default setting of BIOS there. Then reboot. If the problem persists, you can plug the hard disk to another computer and backup the data. I don't see any restore to factory default option for this model. So you can format this hard disk on another machine after the backup and then reinstall the operating sytem using your disc. Try to boot with F12 and choose boot from CD then reinstall it from the scratch. Quicker than check all the details.
Here is a link where you can see which drivers to download from Dell's web site.
http://answers.yahoo.com/question/index?qid=20100519170911AAzAle6
Posted on Mar 14, 2011
Dell latitude e6400 wont boot has black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
- Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
- Check for registry issues
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 16, 2013 | Dell Optiplex 755 Ultra Small Form Factor...
How to safe reboot a dell optiplex 740 to change password?
Restart your computer, and just before the Windows logo appear start tapping F8 on your keyboard. There should be a list of option appear on the black screen. Select the option "Safe Mode" by pressing Enter, wait till the loading. The screen should appear with two or more account including Administration account. login with its password and change the password from control panel
Jan 29, 2013 | Dell OptiPlex 740 PC Desktop
When i boot my computer, it displays JPRGI is compressed. what does this mean
disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer
Jan 25, 2013 | Dell OptiPlex 360 Desktop Computer
Optiplex gx620 starts up but won't go into windows just comes up to start in safe mode but if I select in safe mode it comes back to safe mode. Looked in setup and see an alert "out of range"...
These issues are usually caused by the bad capacitors on the motherboard as Computerscot stated. Here is a repair guide that shows how to check your board for the bad capacitors and what to do if you find them.
http://www.ccl-la.com/blog/index.php/dell-optiplex-gx620-motherboard-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 11, 2011 | Dell OptiPlex GX620 PC Desktop
Dell GX150 Restore
no, you need a repair or mabye at an extreme a clean install.
Feb 23, 2010 | Dell OptiPlex GX150 SF PC Desktop
When I turn on my Dell Inspiron 1520 it will not come up properly. A black screen comes up and states that windows did not start properly. It gives me 5 choices such as starting in safe mode, safe with...
Actually your windows has become corrupt may be due to improper shutdown or power failure.
insert your windows cd and proceed with windows repair.
if you are still in guarantee period,call costumer support for recovery disk
Feb 01, 2010 | Computers & Internet
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Dell OptiPlex GX260 PC Desktop Logo
312 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
