Question about Casio Exilim Zoom EX-Z700 Digital Camera
Flash function not working
Camera was working fine. But then flash function quit working. Won't flash on any setting.
  • 374 Answers
Try resetting the camera. If that doesn't work then it would have to be sent in. In the picture taking mode pess menu and go to the setup tab. Go down to reset and press the right arrow. HIghlight ok and then press select. If that doesn't work then send it in to be fixed.
Posted on Aug 28, 2008
4 Suggested Answers
SOURCE: Flash not working on Sony CyberShot DSC-P93A digital camera
The flash on my Moultrie gameSpy 4.0 (D40) quit working. I can trigger the camera and see the flash is very week. Batteries are 100%. Can the flash be ordered and replaced?
Posted on Nov 30, 2008
  • 11967 Answers
SOURCE: When turning on the camera, the card reader light
Are you saying that even with an empty card, it still takes that long? How are your batteries? Fresh or old?
Posted on Jun 11, 2010
SOURCE: Samsung S730 camera wont take photos with flash
I have the same problem with the same exact camera. Before the flash stopped working, I was taking pictures and the flash was making noise. Every time it flashed, it'd make a loud snapping sound. It only flashed 3 times before the flash finally kicked the bucket... Now I can't take pictures when the flash is turned on.
I read somewhere to try new batteries because the flash might not be getting enough juice, but I highly doubt that's going to work.
Posted on Aug 13, 2010
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Sony dsc-w200 camera works fine until memory stick is installed
Memory sticks now have two types regular and HC. The memory stick is either nor or nand? The new high capacity nand flash cards can not be use in older cameras. Older cameras also have limits on the capacity that it can access. Read your manual to check out the size of memory stick it can use. Most stores sell large capacity memory sticks only good for new digital cameras. you may have to buy older flash cards on ebay.
Feb 09, 2012 | Sony Cameras
Flash zoom function not working
have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Feb 02, 2010 | Nikon Speedlight SB-800 TTL Flash
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture:
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
My flash quit working
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD550 flash not working
most likely it could be stuck
you can try prying up the flash a bit not to much.
otherwise its broken, the gears that runs it, could have a broken tooth.
so it wont pop up or go up.
Jun 23, 2008 | Cameras
Nov 11, 2007 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Empties batteries in 2 minutes
please insert a new pair of batteries and check weather the camera starts in proper manner. does the flash charges. normally even if the camera operates and switches on in proper manner but if there is any problem in the flash section the flash does not fires or do not charge. and if there is a short circuit in the flash section that will result in warming and consuming up the batteries in no time. the heatin of the batteries itself indicates that there is a short curcuit in the camera.
Jun 20, 2006 | Nikon Coolpix 4600 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
105 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
