Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
  • 59 Answers
It may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Posted on Mar 14, 2011
3 Suggested Answers
vincob
  • 718 Answers
SOURCE: My 26cc blower starts up
Do a carb rebuild and cleaning. Check out this website it will show you how to do it smalleng.com awesome site. Good Luck! Don't forget the thumbs...
Posted on Aug 14, 2010
duane_wong
  • 6826 Answers
SOURCE: My leaf blower won't run
Sounds like the Craftsman Leaf Blower's engine has a plugged up carburetor. Try some carburetor cleaner in the tank. Also, try to spray out the carburetor with the spray type carburetor cleaner and see if the condition improves. If it doesn't, then internal orifices on the jets are clogged up and a rebuild is indicated to make it function correctly (and quickly).
Posted on Oct 31, 2010
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My weed eater blower starts and i can run the engine at full
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Jul 18, 2009 | Poulan Garden
How do i adjust carbuerator
Start your adjustment by turning both screws (gas and air) all the way in and then back them out one and a fourth turn. Start from there. Hope this helps.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Leaf blower will not run good. Only runs at full chike or half ch
If the trimmer is more than 3 to 4 years old, you may want to replace the carburetor parts, (new carb. kit). It also depend on the amount of use.
If it is newer than that, then you will need to disassemble the carb. and spray with carb. cleaner. Make sure that the small screen in the carb. is free of debris. Use a Den tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 12, 2009 | Craftsman Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,310 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
