Paper jam. Red light is blinking "paper." Paper is sticking out of the exit area, but do not know how to unjam the paper. Thank you. We put more paper in the unit thinking it would help. It did not help.
    Scholar:
  • 89 Answers
Open the printer cover and tried pulling out the stucked paper. :)
Posted on Mar 14, 2011
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
I have a samsung ml-2010 and the printer light is stuck on red after a paper jam. doesn't seem like there's any other paper stuck. apparently, some folks have said that it's best to take the fuse from the...
It's a very short paper path, you should see a lever near where the paper exits, sometimes that lever sticks, on this machine the red light doesn't go away until you load fresh paper in the tray as well. You can see any leftover scraps when you pull out the toner cartridge, after that any other sensors are hidden inside the fuser assembly, requiring a shop repair.
Aug 07, 2009 | Samsung ML 2010 Laser Printer
Check Paper Light after Paper Jam, Computer says Out of Paper
I have had this problem before. After you checked the paper and it was unjammed and there was paper in the slot and you still had the light on....open the flat where the paper comes OUT.... Look next to where the ink cart. sets when open there is probably a small chunk of paper jammed beside the ink cart. Hope this is of help to you. Good luck!!
May 11, 2009 | HP PSC 1210v All-In-One InkJet Printer
2 pieces are jammed and I can not find access to remove
Is the paper jam in the fixing unit? The Hot area before the paper comes out? If so, I believe if you are looking at the exit section to the rear of the copier there should be a same Green lever that you can move and it will release the preasure of the fixing unit. The only bad news of jams in the fixing unit is if you have any pieces of Black plastic that have came out of the copier, you may have to change the fixing film.
Mar 19, 2009 | Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Computers & Internet Logo
David Payne
David Payne
