Question about Maytag Dryers
I HAVE A MAYTAG LAGACY AND IS TO HOT , TWO DAYS EGO I CHANGE THE CABLE OF THREE FOR ONE OF 4 AND THE RED CABLE IS IN THE RED CABLE OF THE DRYER AND THE BLACK CABLE IS THE BLACK CABLE OF THE DRYER THIS CAN BE THE REASON?
  • 5,911 Answers
Double check your power cord installation. The following link explains in detial how a power cord is to be installed and the differences between the 3 and 4 wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the power cords are installed. Pay particular attention to how you have the ground and neutral wires terminated. If installed incorrectly, the dryer may not run, you could damage the appliance, or you could create an electric shock hazard. If you have questions, please post back and let me know. I hope this helps you.
Posted on Mar 14, 2011
Can i switch the plug on my dryer
If you change the plug on your dryer to a three prong and plug it in that way it will work, however it will not be up to the latest electrical codes where the dryer needs to have its own ground, not share that ground with a neutral. I would recommend running a new wire 10/3 with ground with a new four prong outlet (note: if you already have the 10/3 wire there you can just as easily change the outlet; red and black are hot wires, white is your neutral, and the bare copper is your separated ground) . However if you would like to just change the plug to a three prong you have to make sure your ground bar is tied to your neutral bar and there you only have three wires, 2 hot and one neutral.
May 03, 2010 | GE DBXR463EBWW Electric Dryer
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
I need info for changing the power cord from a 3-wire cord to a 4-wire cord. I have a Maytag Dryer Model MDE9316AYW and I am not sure wher to connect the wires. It looks like they connect (from left to...
The correct way is actually as such...Green (ground) to the frame/chassis. Red, white, then black. See the image I attached for a reference.
Hope that help`s. Good luck.
macmarkus :)
Mar 06, 2010 | Dryers
Im tryin to change from a three wire to a 4 on a maytag Atlantis. Saw some photos... But no luck I have the red on the right white in the middle black and green on the left. And it's not workin
Connect to three post terminal - black and red are interchangeable and belong on the right and left terminals. white goes to center, green goes to machine chasis not to any terminal post
Aug 04, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need to change cords
If your dryer has only the three treminal block you should change the recptacle to a 3 wire. The difference in the 3 and 4 recptacle is that you have 2 hots, a neutral, and a ground prong. Find your dryer breaker in the box and just use the 2 hot and the neutral. Unless you can find a four terminal block for the dryer and even then would it mount to the dryer? Probably not. The extra ground simply grounds the cabinet to prevent damage. Your four wire recptacle may have a red and black(hot) a white(neutral) and a green or plain copper(ground)
Apr 06, 2009 | Amana Dryers
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
Maytag dryer wont heat up
Could be grounded heater element.
Mar 23, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
