Question about Craftsman 14.4 volt Cordless Drill/Driver with Work Light
Have a 15.6v cordless drill - both batteries charge up to ~6v and no more; the red led is on - are both batteries the problem? this is the second charger - drill does not get used very ofter - model of drill is 973.111361
    Sergeant:
    Champion:
  • 250 Answers
See if you can put a volt meter on the metal contacks of the charger to see what voltage it is producing. If you have a friend who has the same drill have him try to charge your batteries and then measure the battery voltage.
Posted on Mar 15, 2011
  • lloydrogers3 Mar 15, 2011
    measured ~18VDC with an analog meter - do not have another charger to check - this is my second charger with same results - can both batteries be defective?
  • Tim Venetis Mar 15, 2011
    It sounds like the batteries are defective. They should measure at least 14 volts.
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
I have a Makita 14.4v cordless drill when I put any of the 3 batteries that I have on charge the charger flashes the red LED indicating that they are over temprature is this the charger at fault as I find...
The chargers also go bad... in this case being that all of the batteries are showing bad I would be getting a new charger and trying that out...
heatman101
Dec 07, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have a 14.4 volt cordless drill that when I try to charge the battery the red light goes from a slow to a rapid blinking after about 60 seconds. The battery does not hold a charge regardless of the...
One thing I,ve found with cordless tool batteries is that if they're completely dead, the charger won't recognize them. Try hooking a known good battery with a charge up to the problem battery, terminal for terminal, with small jumpers. Leave it hooked up for a minute, maybe a minute and a half. this should be sufficient to provide just enough charge to bring the battery up to the "threshold level" required for the charger to recognize it. Then, simply charge the battery in the normal way. If this doesn't work, you may need new batteries, or a new charger. Hope this helps you.
Aug 24, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Batteries not charging
sounds like my charger, not making good contact
wiggle the battery around while pushing down and you can probably get it to make contact
sounds like you just need a new charger
Nov 11, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Metabo 18V cordless drill lithiom ion batteries not taking charge
Some batteries develop 'memory'. Run the batteries down until they are completely dead, then recharge them fully. Do this a couple times to get them back to normal.
Jul 02, 2009 | Metabo 685009520 COMBO 4.1 18V Cordless...
Skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Craftsman 14.4 volt Cordless Drill/Driver with Work Light Logo
296 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
