Question about KitchenAid 24 in. KUDM25SH Built-in Dishwasher
Is there a filter that needs to be replaced or cleaned? After cycle is finished there is still water in the bottom. If I run cancel several times, it pumps it out but very slowly.
    Master:
  • 414 Answers
If your dishwasher is connected to a disposal and it is clogged the dishwasher will not
pump out. Also if it has an "Air Gap", this may have debris in it. It looks like a small chrome
cap next to the kitchen faucet. You can dismantle it to clean it or just replace it. Just be
sure to hook the inlet and outlet hoses up correctly. Hope this solves the problem.
Posted on Mar 14, 2011
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
My kenmore 665.1376 has not been draining. i dont think it is finishing its cycles correctly. when i open the door, the bottom is full of soapy water. i have to wait a day, then hit the cancel/drain...
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if this answer was helpful
Many thanks
Feb 13, 2011 | Dishwashers
Duet Sport Whirlpool front loading washer is stopping before cycle is finished with a variety of error codes from F21 5d etc. Will run fine for several loads then back to not finishing. Have unplugged it...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishes are not getting clean
Hi there.
In the bottom of the dishwashers is normally a filter with a handle on it for easy removal. pull it up, gently, you might have to turn it slightly from side to side to loosen it if it is very dirty. When this filter is out you will see another filter that is just lifted straight up and on that one you might find a lot of dirt.Put both filters in a 10 liter bucket with on cup of chlorine(diluted to 5%) to 5 liters of water. Pour some chlorine( 2 cups) into the bottom of the machine, and close the door and let the machine run on its hottest cycle until finished. When the machine is finished, rinse out the filters in the bucket with warm water. Brush the rest of the dirt off and replace them where they were. Run the machine once again, now on a normal cycle with the dishes in it and I believe they will be clean.
Iceman.
Nov 04, 2009 | Maytag MDB7100AWB Dishwasher
Won't drain
Make sure the garbage disposal is clear so the water can exit. After that, you may have something caught in the drain hose or check valve. It would require removing the bottom kick plate to gain access to check.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Open Questions:
KitchenAid 24 in. KUDM25SH Built-in Dishwasher Logo
83 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
