Question about Konica Minolta bizhub C250 All-In-One Laser Printer
My machine says fusin unit need to be replace i replace ir already and nothing the message still in the scren waht can i do\/
You need to replace a whole new fuser or come with full new PIKO fuse to reset the fuser counter,
its useless if you change an used fuser,
Posted on Apr 23, 2011
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Solution to solve system Error E007 on IR 2016i copy machine
The fuser unit needs replaced. You need a tech with a new fixing unit.
Dec 24, 2010 | Canon iR 2016i Black and White Copier
I AM WORKING ON A CANON IR C3580 COLOR COPIER WITH THE PROBLEM OF INSERT DRUM CARTRIDGE (MAGENTA) BUT THERE IS A MAGENTA DRUM IN IT. WHAT MAY BE THE CAUSE OF THIS PROBLEM AND THE SOLUTION TO IT? DUE TO...
If you replaced this drum already you should have seen all of the sensors! So,1st remove all drums and frnt cover and vac, vac, and vac. We have these machines and have never had this message. There are small boards on the drm units to let the machine know it has a new one. There may be a big glob of magenta toner on it etc. Good Luck
Jun 09, 2010 | Office Equipment & Supplies
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
IR 1600
the copier have a problem with the fixing unit its the thermistor that go off.must change the fixing unit , and do a clear all.
Dec 22, 2008 | Office Equipment & Supplies
My Canon IR c3200 started to print olors out of focus... I read 3 manuals through, transfer belt is clean, auto calibration process gives nothing, horizontal lines printed fine but colors misplaced in...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Oct 21, 2008 | Canon imageRUNNER C3200 Copier
Poor color quality
find out where are the streaks come from, from PC drum, or transfer belt, fusin unit or from toner cartridges. does the trasferbelt and PC drum look okey. finally if nothing is helping, try firmware upgrade and replace printer drivers, sometimes help.
Feb 02, 2008 | Konica Minolta magicolor 2430 DL Laser...
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Nov 23, 2007 | Canon imageCLASS D860 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
115 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
