Question about Weiser Lock Powerbolt 1000 Lock
THE INSIDE KNOB TURNS BUT THE DEADBOLT DOES NOT MOVE ENOUGH TO LOCK OR UNLOCK THE DOOR
  • 963 Answers
Here's the link to the installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Notice on page two that the lock is adjustable for a backset of 2 3/8 inches or 2 3/4 inches, and will work at these dimensions only. You may have missed that step in the installation.
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 05, 2011
How to fix a deadbolt lock that does not retract fully so door unlocks to open
You have to move the lock covering the big hole back toward hinge side by loosing screws and moving to the side till the deadbolt moves back all the way flush. Some deadbolts have a little indent ring to go inside the hole to hold it in position, that makes it harder to move whole thing back. Other brands that indent ring an is only option that you don't have to use. Maybe someone installing didn't put hole in right place, if it's too far off the lock when flush may expose the hole some. Then new door or creative fix to fill gap.
Apr 10, 2016 | Deadbolt Locks & Locksmithing
I can't figure out how to remove deadbolt since it doesn't have any svrews
I think you may have a friction fit type of deadbolt. Remove the door knob or the knob you turn to slide the deadbolt. There should be a shaft that comes out with the knob and was sticking through the inside part of the deadbolt. Now pull the deadbolt straight out, you probably need pliers for this part, be gentle so you don't take the finish off the bolt. I hope this helps, if it doesn't then I may need more info.
Sep 24, 2015 | Deadbolt Locks & Locksmithing
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Weiser Lock Powerbolt 1000 Lock Logo
129 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
