Question about Apple iPhone 3G
Just purchased laptop with windows vista home premium
Will my new laptop communicate with my pc wirelessy running on windows
xp
  • 4 Answers
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Posted on Aug 01, 2008
How do you install windows xp on toshiba satellite p205-s6347
You need a Windows XP installation CD plus the product installation code.
You may find purchasing Windows XP Pro difficult as it is not widely available now and it soon will no longer be supported by Microsoft.
I recommend you keep Windows Vista.
This model Toshiba can installed with Windows Vista home Premium.
Mar 16, 2012 | Toshiba Computers & Internet
I have acer asprse 5315 i just put windows vista home premium .. and it work for 1 week then my computer shut down and its appear on the screen you need a product key ... then i put my lap top product key...
Unfortunately, you have to have/purchase a product key for each copy of the Windows OS, in this case Vista. The XP key will not work. And the key has to be for that particular version ie: Windows Vista (TM) Home Premium.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | Computers & Internet
Describe your acer aspire 7735ZG drivers Problem drivers problem before with Vista now with XP Pro i could not load the right drivers still have problems after one year buying the laptop please let give me...
If you installed the customized(!) version of Windows that ACER supplies with each new ACER computer, namely Windows Vista Home Premium, you should have all of the correct device-drivers.
If you "down-graded" from that version of Windows to Windows XP, and some of the device-drivers are "missing", then I recommend that you reinstall Windows Vista, or purchase an "upgrade" to Windows 7.
You might try to access the manufacturer's web-site, via: http://www.Acer.com
to see if they support "down-grading" to Windows XP, and if they supply the needed device-drivers.
But, your BEST solution is to reinstall Windows Vista, and be sure to apply "Service Pack 2" to Vista, to bring it up-to-date.
Nov 21, 2010 | Acer Computers & Internet
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install http://www.microsoft.com/windows/virtual-pc/ , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
Can not get printer to work with new laptop
is your os vista or xp ? if its vista good luck to you finding a driver it took me over 8 months of searching to find a driver that would run my usb camera need i say more vista was destroyed and old faithfull xp right back in where it should have been all along
Apr 21, 2009 | Computers & Internet
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
I want to remove my Vista Home Premium (64 bit) os and replace with XP Pro
All you need to do is insert your Windows XP disk at start up and boot the disk by pressing any key when prompt to. Then run a clean install since a upgrade will not be available. You may want to backup your programs e.t.c.
Regards
Jan 05, 2009 | AMD Satellite L355D-S7829 Laptop
Xp Drivers needed for Satellite U400-138 to downgrade from Vista Home premium
Yes you can downgrade it to windows xp. go to toshiba website www.toshiba.com and from there you can download the drivers for Windows XP. befor installing Windows XP please download the Network driver and save it on a CD or any other driver. Then install Windows XP. Install the network drivers, connect to the internet and install the other drivers required.
Thanks
Oct 24, 2008 | Computers & Internet
Bios for vista home premium
use the recovery Cd that came with the pc to restore to vista, you probably would not get drivers for your lappie when u install xp.
or use a vista cd to reinstall vista
Nov 23, 2007 | Acer Aspire 5630 Notebook
Apple iPhone 3G Logo
69 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
