I am trying to divide a whole into a smaller number that is a decimal, any help? The question is 5 divide into o.45
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
You didn't specify the make and model of your calculator, so I can't give you an exact keystroke sequence.
The calculator doesn't care whether a number is a whole number or not. Just do the division.
On most algebraic-logic calculators, to divide 5 into 0.45, press . 4 5 / 5 =
On an RPN or RPL calculator, press . 4 5 ENTER 5 /
On most algebraic-logic calculators, to divide 5 by 0.45, press 5 / . 4 5 =
On an RPN or RPL calculator, press 5 ENTER . 4 5 /
If you still have problems, please reply to this post specifying the make and model of the calculator you're trying to use.
Posted on Mar 14, 2011
How do I get answers in decimal format because when I divide I get answer in improper fraction format
You must insert decimal point in equation to get a decimal point in the answer. whole numbers only give whole number sums.
May 22, 2015 | Office Equipment & Supplies
When you are dividing two whole numbers but you need the answer to be in decimal form, how many numbers after the decimal need to remain especially when there many
It depends on what you need. If you divide 100 by 3 you'll get 33.333333333333333333333333333333 and a lot more 3's.
If you need it to be 2 decimals behind the comma your answer will be 33.33 if you want it to be 3 decimals you'll just end up with 33.333 etc. etc.
So it completely depends on what you need to calculate.
Feb 15, 2015 | Google Computers & Internet
How do i change 8 21/50 to a decimal
The whole number 8 remains the same, divide 21 by 50 to find the tenths and hundredths positions of the converted number. Hopefully this helps.
Jan 24, 2015 | Office Equipment & Supplies
What function should it be on to get a whole number answer for division problems EX: 15 divided by 2
15 divided by 2 isn't a whole number.
If the calculator is showing a fraction and you want to see it as a number, press the S--D key to switch between symbolic and decimal values. To have all results appear in numeric form, press SHIFT MODE 2 to select the LineIO mode.
If you want to set the calculator to show only whole number, press SHIFT MODE 6 0 to select FIX 0 display mode.
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
I have the sharp model EL-W535. When I divide not whole numbers for example 9 divided by 5 they come up as fractions instead of decimals and i can change it from fractions to decimals but it's very time...
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 30, 2011 | Sharp ELW535 Calculator
When I divided a problem EX. 3/2 the calculator will not answer in decimal
You are not dividing problems, you are dividing number. This said, there is a simple way to ensure that the results of divisions are displayed in decimal form: It consists in putting a decimal mark (decimal point) at the end one integer (whole number)
ex:
3/2. gives 1.5
3./2 gives 1.5
3./2. gives 1.5
You can also configure your calculator to display all numerical results in decimal format. To do that press [MODE][F2]. Use the down arrow to select the ligne Exact/Approx, then use the right arrow to unfold the menu options 1:Auto
2:Exact
3:Approximate
Select 3:Approximate and press [ENTER]
Hope it helps.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
How to divide fractions
It's the same as dividing whole numbers -- just move the decimal-place.
Sep 10, 2009 | The Learning Company Achieve! Math &...
Calculator
If i type 10+10 it comes up with 10+10=20 and my setting is on Math G . So mabey try that ?
May 07, 2007 | Casio FX300S-TP Calculator
jasbo
jasbo
