Question about Bose Lifestyle 48 System
The remote control is dead; I cann't turn on the command center of BOSE
  • 902 Answers
I would suggest teh best and cheapest solution as remotes for those are really expensive go to amazon.con or a local walmart and purchase a logitec harmony remote series 420 or higher (the 420 or 520 are around 40 bucks now) and it will plug into your pc you tell it what all you have i.e tv model. bose model etc. and it will auto but all the commands on the remote with a screen on the remote for more options PLUS it will also let you set up activities such as watch tv which will automatically turn on tv , turn on your sound system to the right input and the remote will control the volume of the sound system and channels for the tv instead of hitting dvd/life style system button for sound then hittin tv button for channels. i hope this helps.
Posted on Mar 14, 2011
My Bose remote turns on and off withthe comcast remote but the volume does not work unless I hitthe AUX button first. Does not work with the all button pushed.
Since multiple devices have volume controls you must inform the remote which device's volume you are changing. Just like the Power button. You wouldn't want everything in the room reacting to a generic command.
Aug 09, 2011 | Bose Cinemate Digital Home Theater System...
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
Dec 26, 2010 | Bose Lifestyle 28 System
How do you pry apart a Bose RC-9 Remote control without breaking it, to give it an internal cleaning.
There are 3 tabs on each side, and 1 on each end. Pry with a thin flat head screwdriver, but be gentle as you can break these easily. The first tabs are 2 and 5/8 inches from the top end of the remote, with the others 2 inches away from this. The ones on the ends are dead center.
Apr 30, 2010 | Bose Lifestyle 28 System
Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
Nov 02, 2009 | Logitech Harmony 900 Remote Control
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
Where is the IR sensor on a Bose 3-2-1 Series II?
I believe I've found the IR sensor. By shining a flash light on the various parts of the normally opaque shield over the front of the Bose, I was able to spot what I believe to be the sensor on the extreme right end of the shield, vertically centered. Later today I hope to verify this by connecting everything and using the remote through the Xantech. If it turns out that I'm wrong, I'll post again.
Feb 13, 2009 | Bose (321GS) System
Logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Jul 21, 2008 | Logitech (9662080403) LCD Remote Control
Bose Lifestyle 48 System Logo
586 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
