Question about Vacuums
Gas valve on bottom leaks is there anywhere to get a new one.
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 14, 2011
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I replace the hoses on a Hoover Spin Scrub?
I'm guessing you have an F7000 series machine. You have a bad solenoid. When they go bad they don't close so all the water poors out. Take it to your local vac repair shop for the repair.
Sep 11, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a bissell steam and sweep. when I am finished using it water still leaks from the bottom leaving water?
  • Drain the tank after each use.
  • It either has no shut off valve or a broken one when not in use.
  • If its new return it and see if new one leaks or not.
Nov 13, 2013 | Bissell Steam and Sweep Hard Surface...
My steam vac leaks cleaning solution from the bottom
Where the water tanks fits into the body there is a valve that is suppose to keep the solution in place until the trigger is pulled. That valve has gone bad and will need to be replaced. To replace it, take the tank off, pop off the body handle housing with a flat screw driver, then take the two tubes that are gray color that are hooked to the valve, then slide the valve out and replace it with a new one and put everything back together and you should be good to go.
Dec 02, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
