Question about Philips 42PFL5332D 42 in. LCD Television
Just changed 5 bad capacitors on the power board, now two black and white bands about an inch each run vertical in the middle of the screen.
  • 11,361 Answers
Can you still the pictures behind the bands? Did you have this problem before the caps went out? You may want to reseat the cables on the T-CON board also. Did you use low ESR type caps?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 18, 2011
  • Philips Master
  • 1,213 Answers
I would suggest you check the signal board for bad capacitors. These would also be the electrolytic type. Thanks for asking!
Posted on Mar 14, 2011
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
White Vertical strip appearing on AOC L32W861 32 inch LCD HDTV screen
hello, there could a few reason why this as happened 1 there could be faulty capacitor in the power supply 2 there could be faulty ribbon cable and 3 the t con board could be faulty hope this helps
regardsshaun
May 12, 2012 | Televison & Video
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Thin white horizontal line center of screen!
The set should have a vertical output IC,You need to change it ,maybe you can check the B+ going to it because it might have opened the safety resistor if the IC went bad.You can check for broken board too unless the set is never move from one place.Be carefull when checking voltages ,there is still high voltage,not much but can num your whole hand.
Oct 18, 2006 | Coby CX-TV1 5 in. Portable Television
Philips 42PFL5332D 42 in. LCD Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
