Wont change time to spring on my usb - Computers & Internet
  • 27,725 Answers
If you are talking about the time on your computer click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps you
Posted on Mar 14, 2011
My i phone 4s wont charge past 70%
The First solution is that plug and plug tour Charging USB cable. it should work.
nd change the USB Charging because the USB cable pin become week after some time. and also download Battery app for ur Iphone it will tell u every thing. :)
Dec 10, 2013 | Apple iPhone Smartphone
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Im applying pressure in the right direction but the pin wont budge
mcdevito75 here, I'm thinking you mean the stem (winder) Make sure stem is all the way in (flat on the watch) now turn the stem a little both ways, it could be locked down, if the stem turns and doesn't seem to be locked down, simply put a fingernail just under the crown and lift to set the time. If you mean the pin or spring bar to change the band, you"ll need a special tool to remove these pins or spring bars, the tool is available on ebay called a spring bar removal tool, or you can visit a small watch repiar shop in your area.
Jun 29, 2010 | Relic 0504648FA
We changed the battery pack and the bulb and it wont come on so the switch is prolly defective where do we find how to repair the flash light
Alot of maglites are problematic with symptoms like this... I have found that the culprit many times is the screw cap on the bottom of the flashlight.
The elecrtrical connection needed between the spring in the end cap, the threads on the cap and the threads in the barrel of the flashlight...
Make sure you twist your spring a bit..the dissimilar metals can actually corrode between the spring and the cap... Then spin the threads a little... Then try the flashlight again...
This procedure may save yourself replacing a switch..
Apr 29, 2010 | MagLite Rechargeable Flashlight System
Change belts on 2002 kia optima
Not sure what engine you have , but I had an 02 rio with the 1.5 L . The serpentine belt did not have a tensioner (spring loaded) pulley , the belt tightness was adjusted by pivoting the alternator mount.
If you are takling about the Timing belt , the tensioner pulley wont move (even though it is on a spring ) untill you loosen the bolt in the center.
Nov 09, 2009 | 2002 Kia Optima
Pull handle wont rewind
You need to replace spring in pull starter probably. Take you time and be careful or you'll have a lot of spring springing around :>)
Jul 10, 2009 | Ryobi Three Trimmer Combo
Cant connect to computer via USB connection. Software wont open or reads no phone connected.
You probably have the USB selection set incorrectly on the phone. Go to Menu, then Connectivity, then USB, then select "Data Service". The should fix it.
May 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
1994 ford escort wont stay in time
Is it getting the correct tension on the belt. Is the belt tension spring broke. Make sure you have the right belt. On the 1.9 engine they changed it in 1992 from a square tooth belt to a round tooth belt or the other way around. I'm not sure. Just make sure the teeth on the gears is the same as the belt. I know you said it was a 1994 but do you know if a previous owned changed the motor?
May 03, 2009 | 1994 Ford Escort
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
