Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do you scan? To copy you only press COPY and it works.. pressing SCAN does nothing..
    Problem Solver:
  • 18 Answers
When you installed your Canon, you should have installed some drivers and programs with it. If you haven't installed them, you'll need to find the disc and do so first. Specifically, you need the scanning program. Canon products come with MP Navigator which supports scanning. My computer also has ABBYY FineReader, other programs should work too.
Once you've done this, make sure you are logged in and the printer is turned on. Press the scan button on the printer. Now press the Black button, like you were going to copy something. When you do this, you should get a dialogue on your computer asking what you want to do. In the list, select your scan program. It should launch, and then you can scan.
If pressing the Black button doesn't allow you to launch the program, you can also launch it yourself. Navigate to it from Start, then All Programs, then CANON Utilities. Your scanning program should be somewhere in there.
Posted on Mar 14, 2011
    Scholar:
  • 172 Answers
Search scan from the following link
wss
.com/gds/6/0900002716/01/mp160_ug_us_v5.pdf">http://gdlp01.c-wss.com/gds/6/0900002716/01/mp160_ug_us_v5.pdf
and follow instruction ...I hope you will find solution over there....
Please rate & vote if you like solution..
Thanks
Sandeep
2 Suggested Answers
kifuat90
  • 31 Answers
SOURCE: I try to scan a document and does not scan. I
try check the scanner,manually.. maybe have problem there...
Posted on Oct 08, 2010
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
The printer shows repeatedly the following line: The waste ink absorber is almost full. See manual. Unfortunately I can not find any solution in the CD that came with the machine. Thank you for...
Try this combination menu-scan-copy-scan and go to the service menu,then find something like reset ink absorber or reset purge count.I hope help you.
Apr 07, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have a problem with my canon mp130 it is always showing a message codigo de erro 5b00, I tried to reset it by taking off the battery and living for more than 30 minutes, and then the menu -...
Try this:
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Oct 26, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Nothing happens when i press scan button
Nothing will happen unless it's connected to a computer with scanning software running. If you want a copy you press copy and it will scan and make a copy, but if you want to scan you need the software to tell it how to scan, what you're scanning, and how to save the scanned image.
Feb 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
What do I do when it says that ....The Waste Ink absorber is almost full?
1)Enter SERVICE MODE by pressing MENU-SCAN-COPY-SCAN
2)Enter NVRAM by pressing < or> then OK
3)Set ABS-M to 0
4)OK
Feb 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
Oct 29, 2009 | Brother MFC-5840CN All-In-One InkJet...
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Nothing happens when I press the scan button
When you press scan, the unit must be connected to your computer and the computer needs scanning software running, if you want to make a copy you press copy and it will scan and print, in order to scan it needs to know where and how to scan and where to store the image.
Sep 14, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma mp130 printer waste ink absorber is full nothing in manual on how to fix
plz read the article in the link below
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Jul 20, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
