Question about Dell W3201C 32 in. LCD Television
Sound went out think its the speakers but not sure
  • 51 Answers
If there is a buzzing sound coming from the speakers, when you listen closely the speakers probably went out, you should try connecting external speakers to the tv, if they work you know its the speakers if not, then it may be the TV screen itself, hope this helps.
Posted on Mar 14, 2011
Very low volume on all inputs
first thing,,,,make sure the speaker wires are not touching each other.
i dont think it would be a fuse because that would cut the sound completely.you could open the unit to check for a fuse or fuses.
if none of the above help,then take the unit to a tech.i suspect a blown channel which means a capacitor needs to be replaced.one more thing...swap speakers over to make sure your speaker isnt blown
Oct 17, 2015 | Marshall Stanmore Bluetooth Speaker
Well I just bought the Logitech ls21 2.1 speakers and subwoofer and I am having a few problems. A small problem is that I think something may be wrong with the wiring. The speaker output only works if I...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 19, 2011 | Logitech LS-21 2.1 Speakers
My speaker on my computer don,t work what can i do to solved the problem.
see if you broke the wires see if they came unpluged make sure that they are in right hole it sould be in green hole or the speakers went bad that all i can think of jim or sound card is bad
Mar 28, 2011 | Computers & Internet
Sound went limp i think it the crossover
Define limp. No highs or no volume?
Logically, what one thing would affect both speakers? Logically, how would a crossover failure mute anything but the tweeter?
So, what happened just BEFORE this problem appeared?
I'd look at the electronics.
Feb 25, 2010 | Polk Audio R40 Speaker
Better sound through bose speakers?
If you have the money to plunk down for a Bose Acoustimass home theater speaker system, I'm sure you will be quite pleased. Of course, as you indicated, appropriate placement of the speakers is important. Still, I'm sure you will find that a properly placed Bose Acoustimass speaker system will fill your room with high quality sound, substantially better than Onkyo's stock speakers placed equally well.
I own a Technics home theater system, which I initially purchased to use in my family room. Yet, when I listened to a Bose Lifestyle system (powered by Bose Acoustimass speakers), I could have nothing less. The Bose system went in the family room, where everyone could enjoy it. I put the Technics system in the bedroom, where it is rarely used.
Jan 09, 2010 | Onkyo HTR500 Receiver
The sound just went off completely did the speaker
I doubt that your speakers blew, I would think that it was the audio driver.
Check to see if you have an audio out and hook up a external amp for sound.
This may be the best way for you to get sound out of your television for now. The repair may be too costly
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 02, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
Oct 05, 2009 | Dell A525 Computer Speakers
I have a 2000 eclipse....i just put in one of those touch screen cd players with a 7 in screen....now it kinda sounds like **** because i think the dashboard speaker went...can i just buy door and back...
yes. You don't need the dash speakers, you can just put door and rear speakers in. Also for the front you can get component speakers and put the tweeters in the dash. Trust me, it will sound great! Make sure whoever is doing this knows what their doing because another thing that can cause your system to sound bad is phase and polarity problems.
Sep 03, 2009 | Dual Dash Speakers 3" Cone Car Speaker
No speakers working
It would sound stupid, but just in case, have you checked your volume level, is it set to lowest .
Connect one speaker at a time and check ?
Mar 15, 2009 | Dell A215 Computer Speakers
Dell W3201C 32 in. LCD Television Logo
128 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
