Question about QuickPAD IR Keyboard
How do I set the password for an individual folder; i.e., F1 I want to password proctect the folder as well as rename the folder.
    Scholar:
  • 135 Answers
Http://www.addictivetips.com/windows-tips/how-to-lock-and-password-protect-folder-in-vista/
  • 1 Select the individual folder that you would like to password protect. If you will be protecting multiple folders, it is easiest to place all of these folders into one larger folder and simply add a password to that master folder.
    However, it is also possible to add passwords to folders at multiple levels within the folder arrangement. This is an excellent way to allow certain users access to some documents by giving them the password for the higher level files while making the master passwords for the interior folders available only to those who have access.
  • 2 Highlight the designated folder, and left click on it to open the drop-down menu. Select the "Folder Information" option, and open the Folder Information menu. This will give you access to the various preferences that are adjustable for each folder, such as color, icon and name.
  • 3 Click on "Password Protect," which may be on the main menu or on a "Settings" or "Security" tab. Apply a level of password protection that fits your needs. Set a password for the folder that will be easily remembered. Click "Apply" in the bottom right corner to make the changes permanent.
  • Posted on Mar 14, 2011
    Always I get this message about the password of that corrupt profile when I try to fix it Windows Vista the profile user cannot be loaded.
    Go to Safe Mode. Type REGEDIT. Select HKEY LOCALMACHINE. SOFTWARE, MICROSOFT. WINDOWS NT. PROFILE LIST. In PROFILE LIST are two folders with the same name but one has .bak suffix. RENAME the plain one with .ba suffix. Rename the .bak to plain with no suffix. Rename the .ba to suffix .bak. In the now plain one with no suffix, open it and find REF COUNT set it to 0. Open State and set that to 0. Save the files and reboot.
    Hope that helps.
    Dec 02, 2014 | Computers & Internet
    Tip
    How to rename or move a User Profile folder ?
    To rename (or move) the User Profile folder, you may use the following method. This method has been adopted from KB314843, but this page explains in detail how to rename an User account home directory.
    Though you can move or rename the user profile folder, there may be some side-effects after using this method. This is because of the reason that there may be some absolute path (to the old user profile folder) references in the registry, made by third-party software. Therefore, there may be a loss of functionality in some third-party software which stores the file locations as absolute paths, in the registry.
    Before modifying the registry, you need to take a full backup, in case you want to Undo the changes or to recover from disasters caused by incorrect registry modifications if any. You may use ERUNT for a full registry backup. Use Registry Editor at your own risk
    Rename the User Profile folder using Windows Explorer
    • Logon to an admin account that is not the account being renamed.
    • Open the Documents and Settings folder, by typing this in Start, Run dialog:
    %SystemDrive%\Documents and Settings
    • The list of folders will be displayed. Select the corresponding folder of the user account that you want to rename.
    Example %SystemDrive%\Documents and Settings\OldUsername
    becomes
    %SystemDrive%\Documents and Settings\NewUsername
    Next step is to notify the registry that the folder has been renamed (or the Profile Path has been changed)
    Changing the ProfileImagePath value in the registry
    ProfileList key, SIDs and the ProfileImagePath value The ProfileList registry key contains some sub-keys, which are nothing but the list of User Account Security Identifiers (SID). Each of the SID represents an Account. The key is located here:
    HKEY_LOCAL_MACHINE \ SOFTWARE\ Microsoft\ Windows NT \ CurrentVersion \ ProfileList
    Identify the SID for your User account, and change the Profile path
    • To know the SID for your user account, you may use the script sidlist.vbs
    • Download the script and run it. (The User Account names and SIDs will be listed in a log file, and opened automatically.)
    • Note down the SID for your account.
    • Then, in the Registry Editor, select the correct SID that belongs to your user account.
    • In the right-pane, double-click the ProfileImagePath value and set the correct path and folder name. ( The ProfileImagePath stores the full path of the User account home folder. )
    becomes the following:
    You're done now. Close Registry Editor, and restart Windows. See if you're able to logon to that user profile successfully. Additionally, to verify if the path has been changed successfully, type SET in the Command Prompt. If you find any abnormal behavior while running an application (in case), you may Undo the above procedure. Then you may use the Copy To Profile method instead to accomplish your task.
    on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
    Administrator password
    restart the computer and HOLD the keys FN+f1 or f2 depend of your model and mark, and go to the BIOS setup and rename the password and fix it.
    God bless you
    Nov 16, 2013 | HP Computers & Internet
    When renaming sony handycam files .. they don't work.. it says no applicable files available?! .. i have to rename the files like "M2U00348" .. is there a better and a quicker way??
    why are you trying to rename these files
    why do you have to rename these files
    by renaming individual files this might make them incompatible
    if you make a folder named M2U00348 then put the files in the folder
    hope this helps you
    Mar 08, 2012 | Sony Handycam SR68 Red 80GB Hard Disk...
    I have lots of pictures in the one folder. Can I number them consecutively without doing it individually? I have Windows Vista Home Premium. Thanks
    if you want to move them all hold ctrl and a then ctrl and x at the same time and then were you want to put them open the folder and press ctrl and v.
    Jun 06, 2011 | Microsoft Computers & Internet
    My administrator account is corrupt and i can not log into it, but luckily i have the guest account turned on but with this account i can not create a new account like an administrator one. so how do i...
    Without using 3rd party pay-for tools, I would recommend locating the Windows CD that came with the machine. I would then boot to the CD, and use the Recovery Console option. When you get into the recovery console, you should be able to log in using the administrator password only. This doesn't load the Administrator profile, it just uses the password for permissions reasons. I would then navigate to the Documents and Settings folder (assuming this is XP) and rename the Administrator profile folder to something else. Once you rename this folder, restart the computer, log in as Administrator again, and Windows will create a new profile for the Administrator, and leave your old one alone. Once you're logged in, you can browse to the old profile and get your files and pictures back.
    May 11, 2009 | E-Machines eMachines Desktop PC
    How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
    Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
    Mar 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
    Keyboard F1 to F12
    F1 - F12 Function Key Usage
    Printer Friendly Version
    F1:Help. Click F1 Key can load the help file of the program.
    F2:Rename. Select a folder or file, click F2 to rename it.
    F3:Search. On desktop, click F3 to load the search form.
    F4:In Internet Explorer, click F4 will list the URL Address field.
    F5:Refresh. Use it to refresh the web page in Internet Explorer.
    F6:In Internet Explorer, click F6 will jump to address bar.
    F7:It can be used to insert ^C in command prompt.
    F8:When windows startup, it can load the startup menu.
    F9:In Windows Media Player, it can increase the volumn.
    F10:In Windows Media Player, it can decrease the volumn.
    F11:In Internet Explorer, click F11 will switch to Full Screen mode.
    F12:In MS-Word, it will show out the "Save-As" dialog.
    Take this link u will get all the Function Keys description
    http://www.computerhope.com/issues/ch000306.htm
    Aug 31, 2008 | Computers & Internet
    Is it possible to rename digital pics on HD in large groups?
    defaults to naming a folder for the date it was created. You should be OK if you accept their default. I usually go in using thumbnail view and re-name my photos when they are downloaded. You can rename the folder before downloading. I deleted Image Zone for my HP camera due to a conflict with my HP scanner, but if I remember correctly, you right click the default location name and rename to suit you.
    Aug 30, 2005 | HP Photosmart C200 Digital Camera
    QuickPAD IR Keyboard Logo
    90 people viewed this question
    Top QuickPAD Computers & Internet Experts
    David Payne
    David Payne
    Are you a QuickPAD Computer and Internet Expert? Answer questions, earn points and help others
